part of my track wont work
Oct 11, 2004
301
New York. Oneida
try taking a pair of ruber handeld pliers and place loco on the dead track place pliers on one side of the jaw on live joint/rail and place the other jaw on the dead rail/joint or pich you connectors together.
4,501
Lakewood, Ca.
mr. bubbles said:
yes some track turnes out then rejoins in the other direction, and the track worked before
Welcome to the Gauge mr bubbles.
What do you mean by "It worked before." Did it work with the track in this configuration or did it work before you put the reversing track in? With two rail dc, any track that reverses the direction of the train will create a short. To make it work you need to use indsulated rail joiners, with a double pole double throw switch to reverse the polarity while the train is in the reversing section. If you can draw a picture of your track plan, we could probably help you more with the problem.
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
Thats exactly what i was going to suggest.
