Parking Lot Pic
Discussion in 'Photos & Videos' started by Joepomp, Apr 24, 2005.
  1. Joepomp
    Joepomp Member
    I just put in the paking lot behind the round house. I used white foam board. I bent it here and there for to make cracks and since it is used stuff from work the surface is pealed in many places, makes nise pot holes. I sprayed it Dark gray, but it looked like a epoxy painted basment floor! Then I tried flat black that was too black. Then I put the plaster around the lot. Well of course I got plaster all over. As it turns out I used a wet paper towel to remove the plaster. It left a gray film and after repeated plaster applications and clean ups it doesent look to bad. God I love this hobby! The more you messup the better things look.
  2. TomPM
    TomPM Another Fried Egg Fan
    Looks great!
    You are right, waht other hobby can a foul up become a solution. Can't tell you how many of those I have.
  3. shaygetz
    shaygetz Active Member
    Real enough that some poor sap's car got its tires stole right out from under it ;)
  4. Chessie6459
    Chessie6459 Gauge Oldtimer
    Looking Good :thumb: :thumb:
  5. ezdays
    ezdays Out AZ way
    Yep, looks good. It becomes difficult to do if you work at it. Messing up is easier and more natural looking in the long run..:) :)
  6. Matthyro
    Matthyro Will always be re-membered
    It sure turned out well JP. Nice work.
  7. SteamerFan
    SteamerFan Member
    Not only that, they stole just the tires and left the rims! guess metal isn't worth stealing anymore. :p
  8. Ralph
    Ralph's for fun!
    That turned out really well! Very realistic!
  9. toolman
    toolman Member
    :thumb:The parking lot came out great and what you did gave some sort of what I should do with my industries parking lots, and to go one step further some areas flooded.
  10. spitfire
    spitfire Active Member
    Looks good Joe! You did a really nice job on the white lines. Did you mask and airbrush them?
