Paper Replika T-47 Snowspeeder (rescaled + pilots)
Tirick
369
20
18
Ontario, CA
tcfgaming.com
What you see here is a rescaled (1:50) build up of Jules Perdana's T-47 Snowspeeder, (which can be found at http://paper-replika.com/) with pilot figures of my own design seated in the cockpit.
It has been several months since I finished the base build of this beauty, and its been waiting for my pilot figures to be complete. While a bit difficult to build scaled down (the original scale is 1:20) it was a pleasure to have all of it come together so neatly and with very few fit-up issues. The WIP thread can be found at Paper Modeler's Forum (I'll dig up the link once the site is back up), but I wanted to share the final assembly pictures here.
The two pilots are from my Paper Protagonist series and are available for download here. As the snowspeeder cockpit is a bit poorly designed (Not a fault of Jules' I must say: they had to add 'box' structures to the set prop to make room for the actors' legs), so I had to shoehorn the pilots in place and truncate their legs. In retrospect I probably should have just made the scaled version a bit bigger to accommodate, but I am a scale junkie and my OCD wouldn't allow it.
I only made a few minor changes to the model, adding an acetate floating base, hinges to the cockpit and clear acetate wedges to hold the canopy down. The last picture has a Canada penny (2 cm diameter) in the shot to give you a sense of size.
Enjoy!
Sean
Elliott
645
<best Darth Vader voice>
Most impressive! Indeed you are powerful. Obi-wan has taught you well.
:mrgreen:
Tirick
369
20
18
Ontario, CA
tcfgaming.com
Thank you!
Pictures are hard to convey the size of the model as the physical model is actually only 1/4 the size of the pictures on my monitor. I'm actually astounded it looks as good at high-rez.
It is sitting beside my B-wing on the desk at the moment; I'll have to make up a Hoth hanger at some point to display them properly.
Sean
Elliott
645
Beautiful work Sean. I can't put my finger on it but there's something about multiple models together that makes a great picture, at least to me. I love the et al in the pictures! Thank you for the pictures and inspiration. :thumb:
crates
8
i had a go at making this myself, realy nice model.
i'm impressed at how well you've made yours, good job.
Tirick
369
20
18
Ontario, CA
tcfgaming.com
;) the pilots are available on the same site, although the snowspeeder does not 'fit' them. This is evidenced in the various model kits over the years, as well as the fact that the 1:1 scale filming models had an extra 'box' for the actors legs to go.
