one more question
Discussion in 'HO Scale Model Trains' started by blahblahtrain, May 22, 2006.
  1. blahblahtrain
    blahblahtrain New Member
    i have a sheet of ply wood that my train will be on, and i have grass sheets to lay on the plywood, and my question is, for the wires to all the lights, like lamp post and stuff like that, do you drill a hole all the way through the mat and plywood, or just run the wires under the grass mat?
  2. stuart_canada
    stuart_canada Member
    drill thru everything , and run the wires under it out of sight
  3. yellowlynn
    yellowlynn Member
    Not only out of sight, but available if you need to do something with them.
  4. jim currie
    jim currie Active Member
  5. TruckLover
    :wave: If you don't drill all the way through, you might end up having the wire snake away from where you want it and then have to re-do it all. That would suck!!wall1
  6. Russ Bellinis
    Russ Bellinis Active Member
    I think you will have trouble drilling through the grass mat. It will probably want to twist into a knot around your drill bit. What you will need is a leather punch to make a small hole in the mat slightly bigger than the diameter of the drill bit you use to drill through the plywood. I'm not susre where you live to advise you where to get a small punch. You would need what looks like a chisel with a hollow punch end. You might check a local craft store to see if they have one in stock or can get them. Tandy/Leather Factory manufacture them for leather crafters and saddle makers. If there is a leather craft store or saddle making shop near by, they might be able to help you. I just ran a google search on Tandy/Leather Factory and got this link to their web site. They sell wholesale and retail, and may sell on line mail order. On their menu go to hand tools and then to punch sets. You would want either the mini punch set part # 3003-00 or the maxi punch set part # 3004-00. don't worry about a cutting surface to protect your table top. If you glue the grass mat down first, then punch out the grass where you want the wires to go, you will automatically locate and center the drill for drilling the hole in the plywood.
