New template Tie Interceptor
mijob
Tie designer
3,244
5,480
95
Netherlands
Sorry to hear you had to reinstall your computer. I hope you didn't loose any data.
seraphim
269
580
a few things, but luckily i backed up on another drive, but have to reinstall everything lol. Getting there slowly, just been a bit nuts alongside hospital appointments and being in the middle of sorting our place out too, always the way i guess, but progress is being made :bulgeeye::yesyes:
mijob
Tie designer
3,244
5,480
95
Netherlands
the level of detail you put into your builds is next level. definitely alot to learn from the masters here :toast:
Thank you so much for your kind words. I have learned it also so it no problem for you to learn. Take it slow at the end you will get there.
  • Love
Reactions: seraphim
mijob
Tie designer
3,244
5,480
95
Netherlands
I really like the level of detail that you have put into these wings. You are raising the bar rather high for these models. You have definitely made these your own.
Thank you so much. If I compare it with the model from UHU its indeed a huge difference. But a lot of work to get all the details on there place. And they are realy small and a lot of them
mijob
Tie designer
3,244
5,480
95
Netherlands
Done and sprayed with a clear coating.
Some pictures.
20240509_190647.jpg20240509_190659.jpg20240509_190709.jpg20240509_190718.jpg20240509_190728.jpg20240509_190739.jpg20240509_190750.jpg20240509_190806.jpg20240509_190817.jpg
Ie will take beauty shots at a later moment.
Next up is making the building instruction and cleaning up the template. Then I have to decide whats my next model will be.
Maybe a redesign on the Tie Fighter with an add on ;-). And I have to build some other Tie Interceptors. See you all back on my next build thread. Cheers :toast:
ennder
459
1,111
83
mijob, you keep this level of excellence up and you might be getting a job offer from Revell or Monagram.... or ILM:)
I LOVE your models. thank you for all your hard work.
Reactions: mijob
9,594
That is the best Tie Fighter model I have seen. I remember none that have the panels as detailed as yours, and the rest of the model is at that same level. You are on the top of the ladder. Excellently executed!! :)
Reactions: mijob
