Nell from Battle Beyond the Stars
12,462
Indeed. It would be doable by cleverly using simplified shapes. Julius Perdana is a master of that. :)
Gandolf50
1,327
1,576
96
New Mexico USA
I think the center image says it all.
12,462
It can be done.
You have to start with a fairly simple roug shape to get the idea of the part. Then you subdivide the faces and manipulate them until you have the desired shape. It is a tedious job and is best acieved with the goal (= papercraft) in mind. You must not overdetail the shapes and have to be sure about the final size of the model.
Gandolf50
1,327
1,576
96
New Mexico USA
If you forget for a moment about creating from a flat sheet and use other methods to form an organic shape, combined with a bit of water forming and burnishing, you can create just about any shape that can be flattened and cut.
For Example. It still would have to be designed, but far better method as a start!
9,599
This may be edited out, but that ship looks like someone cast their balls and split the penis right down the middle. There, I said it. :eek:
Reactions: lyter1958
Sky Seeker
Well Established Member
Jun 1, 2015
1,178
1,083
95
I think that the intention was more akin to the middle b&w picture above. Methinks flirtation oh I mean flotation "devices"!:biggrin:
Reactions: zathros
