Need scratch build advise.
Discussion in 'Scratchin' & Bashin'' started by jkristia, Jun 14, 2003.
  1. jkristia
    jkristia Member
    I building my first scratch build structure, based loosely on the Santa Susana Depot in Simi Valley. Since it's my first building, I know that it won't be perfect, but of course I would like to get as close as possible. The picture shows where I'm at right now, and that's why I need some advise. What would be the best way to do the windows and doors? I'm thinking of trying to build them from 0.020" x 0.020" styrene strips (roughly 3x3" in N scale), but don't know if it's possible or if it's too tiny. If that fails, I might try the drywall mesh thing.
    But any advise of how to achieve the 'right look' will be appreciated.
    I have a picture of the real depot here
  2. Tyson Rayles
    Tyson Rayles Active Member
    It looks like you are doing a very nice job so far. I would check a Walthers catalog for Grandt Line window and door castings. Depending on what scale this is you might find other companies that make em' as well. Look under super detailing parts or scratch building supplies. :)
  3. davidstrains
    davidstrains Active Member
    Like Tyson said, looks great so for. Another suggestion for the windows is a tip that I received from errol (kettlestack). He scribes the window frames and pane dividers on clear acetate with a draftmans pen and ink. They look very good.
    I have not worked with styrene so I can not advise you on that. Just have fun.
  4. csxnscale
    csxnscale Member
    Jesper, this doesn't look like scratchbuild, it looks like $$$$$ kit.
    Good job.
  5. jkristia
    jkristia Member
    Sorry, forgot to mention it's N scale and I have already checked Grandt Line, they don't have exactly what I'm looking for, but actually now when I think of it, maybe I can make one of their windows fit. Thanks for the idea.
  6. jmarksbery
    jmarksbery Active Member
    Fine Job,
    It is hard to find just what you want all the time, but I am one if it looks good to you use it. The building inspector here on The Gauge is not to critical. :p Unless you are detailing the interior paint the inside walls black to give it a lived in look, also if lighting it will keep the light from shineing thru. Looking good :eek: :eek: :rolleyes:
  7. jkristia
    jkristia Member
    ok, I give up. Today I have spend more then 2 hours trying to make the first door, and hasn't been able to come up with anything that looked even close to decent, so I decided to forget about what the real doors and windows looks like and instead use some Grand Line windows and doors. Unfortunately, the window openings doesn't match the Grand Line one, so I will have to do some filing and filling to make it fit, but I'm sure the end result will be better than if I try to make the windows myself.
  8. Ralph
    Ralph's for fun!
    No shame in using commercial parts to make what is already a fine looking model even better! Nice start on this structure! Looking forward to seeing updates!
  9. Matthyro
    Matthyro Will always be re-membered
    Hope it all comes out the way you want it to Jesper. That's a good looking sructure. Some of us use widows and doors we draw using MS paint but they don't look as good closeup. We have also used dry wall mesh tape for windows which looks quite good in N scale.
  10. jkristia
    jkristia Member
    I have been following and admiring all the buildings you have been posting for a long time, and I know about your drywall mesh technique, and if anything else fails, I will try that. It's just that I would like to see if I can find something that comes closer to the real thing if possible.
    Right now I'm waiting for the Grand Line windows I ordered, so lets see.
    Thanks again everyone.
