Need input!!!
shamus
Registered Member
Dec 17, 2000
3,489
UK
Website
Hi Andy, looked at your website, very nicely laid out but the photo's need working on, some are out of focus, do you own Paintshop Pro 7 or similar package. If not, I would be only too pleased to clean them up a little for you. I did one this morning just to see, sharpened it and got rid of the noise around it.
Hope you don't mind friend.
shamus
NARA Member #24
http://www.badger-creek.co.uk
Thanks Shamus
Shamus:
I use Corel Print House. It's not the most powerful print program. I scan the pictures in at high resolution then change them to 72dpi and save them under a different file name. This saves space on my site. I would gladly accept any modifications from you! ;) I have a Print Shoppe 4.0, but that's too old. :eek:
Thanks again,
Andy
scudrunr
21
Maine
Rather than take picures with flash, use the standard light you have over your layout W/o flash, the pictures will show more even though they may be yellow. its a chance i'm willing to accept.
shamus, what did u use for when you took the pictures of beaver creek?
shamus
Registered Member
Dec 17, 2000
3,489
UK
35mm
Hi scudrunr and welcome to the gauge,
For Badger Creek Lumber Company, I used a Minlota X300s 35mm camera with Daylight Flourescent Tubes spaced at 18" intervals on the ceiling.
cheers
Shamus
NARA Member #24
scudrunr
21
Maine
Andy, even if you are not using top of the line camera equipment you should be able to turn off the flash. I guarantee pics will look better
