Need Help
Discussion in 'HO Scale Model Trains' started by UPJunkie, Aug 21, 2004.
  1. UPJunkie
    UPJunkie Member
    I need to know how you guys make your forest that looks like alot of trees are there :confused:
  2. rcline
    rcline Member - this is good place to find trees and also you can do clumping of flock and foliage. I forgot which thread it was in here, but several of the experts gave some really good advice on trees and mountains. I myself, spend an hour or so in here everyday just reading and learning
    what the experts have to say. It will really help you a lot.
  3. CN1
    CN1 Active Member
    Mastiffdog has great looking trees on his layout. :thumb: I can't remember wich topic the pictures are. :cry: But here's a great tutorial on How to make trees by Mastiffdog.
  4. Fred_M
    Fred_M Guest
  5. SAL Comet
    SAL Comet Member
    Ha Junkie, I agree with Fred, My guess is the forest in your picture has only a few trees with a trunk, the rest being just folage clumps. Since it's so dense, you wouldn't be able to see the trunks on all the trees anyway.
  6. shaygetz
    shaygetz Active Member
    Allen McClellen does it by using plain Poly Fiber fill used for stuffing pillows. Get several shades of cheap flat green spray paint and ground foam. Pull off small clumps of Poly fill and roll into 2-3" balls. Spray them real well with green paint then drop them into a box of ground foam. Roll them around in the foam, pick them out with tweezers and allow to dry. Spray them with some clear flat and again, allow to dry. Take a round toothpick and poke it into the desired location, run a dribble of glue and poke a clump onto that. Won't be long before your hills is covered... :thumb:
