Need Help Once Again.
Discussion in 'HO Scale Model Trains' started by Chessie6459, Oct 21, 2004.
  1. Chessie6459
    Chessie6459 Gauge Oldtimer
    I have been wanting to repaint a tank car in the Union Pacific Yellow. The tank car is painted primer right now but i need to know what colors i could mix to get the yellow that the UP uses for their locomotives. I am going to run the tank car in-between a GP38 & a FP45 or it is a FP40 not to sure (both are UP Locomotives) cause these units will be placed into helper service until i can purchase a couple of SD40-2's & SD45's. Any advice will be helpful. Thanks in Advance. :wave:
    P.S forgot to mention that it is a former Hooker Tank Car so it willl not be the the ones that the UP had for their turbine locomotives.
  2. Russ Bellinis
    Russ Bellinis Active Member
    I think Floquil sells Armour Yellow in both the old Floquil line and the new PolyScale line.
  3. Chessie6459
    Thanks Russ i will check into that :wave:
