Neat Sweet Petite - Haunted Dimensions
9,559
If you print another sheet, and cut out the shrubbery, then glue that over the existing, it will make the model pop. Some "N" scale model railroad stuff would probably work too. You could give the window frames the same treatment. This looks wonderful. I built a few houses for a "N" scale set up I had, boy did I save a lot of money, those little houses are expensive to buy. :)
Rhyming_Rogue
23
73
15
56
Thanks for the encouragement. I remember Gomez Addams liked to crash his model trains into each other, but he was rich enough that he didn't care about the expense.
