N scale LL Proto N GP38-2
Discussion in 'N / Z Scale Model Trains' started by csxengineer, Feb 10, 2008.
  1. csxengineer
    csxengineer Member
    I haven't seen them run, do they run as good as an atlas or kato 4 axle engine, or are they just a typical life-like engine with better details and couplers?
  2. SD90
    SD90 Active Member
    I haven't seen them run either, but I would assume they are just better looking LL's!
  3. Squidbait
    They're no Kato, but they're definitely a better loco than the straight LL.
  4. Catt
    Catt Guest
    Like KATO locos the LifeLike units have an ATLAS clone drive.They look good,they run good,and they pull good. :mrgreen:
  5. Herc Driver
    Herc Driver Active Member
    I've got three of them and one runs well...while the other two seem to have an electrical problem that I haven't figured out yet. They run well then all of a sudden stop...start...the stop. If I touch the shell very gently, I can get them started again. Whatever the problem is (and it's on my list to do) I'm guessing it's very slight since it doesn't take much to fix it...Overall, they look great, run smoothly and are only slightly louder than a Kato. I'm happy with them - even the ones that don't run without problems - and would buy a few more if needed. And as soon as I figure out what the problem is with the other two units...I'll be running a string of three and enjoying them even more.
  6. brakie
    brakie Active Member
    I seen 'em run at he N Scale club I am a member of..They are smooth runners but,I would go with the Atlas GP38-2s since they have about the same MSRP-LL $99.98.Atlas $99.95..Also the Atlas GP38-2 has a cheaper discount price.
    Atlas:$67.49 Vs. LL at $74.95.
    IMHO the Atlas will be the better of the two.
  7. woodone
    woodone Member
    Anybody install a DCC decoder in one of the LL's
    They have a split frame and the instructions with the loco said to remove the light board and install a DCC board and your set to go.
    The problem is that I don't see where anyone that makes a DCC board for this loco.:confused:
    Any help?
    Thanks in advance
