More silver cardboard balloons for water
Discussion in 'Photos & Videos' started by hminky, Jul 13, 2005.
  1. hminky
    hminky Member
    I found this silver balloon on the internet:
    It has a real good ripply texture and has more shine than the larger balloon from my earlier post. It is available from:
    You get 12 for $3.95 but the shipping is $6.95. About the cost of any other water method.
    Just a thought
  2. ezdays
    ezdays Out AZ way
    That just struck a nerve in my brain. There are many foods that have a piece of cardboard with silver on one side between the jar and the lid. Even some nut cans have this stuff on their easy-open cans. And the price is right too.... It may not be big enough for O scale, but surly enough for N.:D
    Keep these little gems coming, we all gain from what you're doing. Thanks...:thumb::thumb:
  3. Doc Holliday
    Doc Holliday Member
    Great idea Don,
    Lotsa microwave foods, such as Hotpockets and frozen mini pizzas, have sleeves lined with a similar material. Now we have an excuse for a tasty snack while modeling.
  4. SAL Comet
    SAL Comet Member
    Oh Yaah, Poptarts
  5. CAS
    CAS Member
    You can also get those balloons at party stores.
  6. hminky
    hminky Member
    Here is a piece of the cardboard balloon temprorarily glued to my
    old retaining pond:
    The food containers usually lack rippling, I got a bigger cardboard ballon at a party store and the texture wasn't as good. These are ten inchers.
  7. brakie
    brakie Active Member
    The only thing I can see about using that balloon it unnatural in looks unless its a man made pond. :( Also a pond that size would need a inflow and outflow of water if not then the pond would eventually dry up with no inflow of water or would flood without the outflow..Now if that pond is fed by a underground spring it would still need a outflow even if its no more then tile running to the nearest ditch line..Savvy? IMHO all of this needs to be figured in when we design a pond. :D Still a great idea that is workable. :thumb:
  8. hminky
    hminky Member
    I have seen spring feed ponds without an outlet. An extreme example: a desert oasis
  9. brakie
    True,but the sand usually sucks up the overflow or it evaporates from the heat. :D Now exactly how many of us model a desert? :confused: :eek: :D
    Again close attention to details is a must for better modeling that leads to a highly detailed and greater looking layout.. :thumb: :D
  10. N Gauger
    N Gauger 1:20.3 Train Addict
    :D :D I'm buying stock in frozen food... I can see this coming... starting to buy the food - just for the lids! :D :D
    It is a good idea and you can make it any shape you want. Plus add an inlet (or spring fed) & outlet :) :)
  11. hminky
    hminky Member
    That is why I am looking for a better way to make water. Resin on black looks like resin on black. Most model water in real life doesn't look like water. Looks good in photographs.
    Here is Dunrobin Lake in the Canadian Province of Ontario, a large artesion spring fed lake with no outlets.
    Here is my rendition of rushing water using Woodland Scenics Realistic Water and silicon caulk for the white water:
    I have web articles with my attempts to build a layout at:
    I do pay attention to details
    Just a thought
    P.S. The tunnel portal is too big because we are in the process of coverting from On30 to OO scale 1870's standard gauge
  12. brakie
    Harold,Is that a settlement pond of some type? Is that a inlet drain pipe about the center top of the pond? What color is that water or is it just muddy? :confused:
    Anyway,I like your rushing water..You are correct..A lot of model water I have seen to blue or to black..Again I like the idea of using those balloons for water as it seems easy to use and should be easy to cut into other shapes.. :thumb:
    You said:I do pay attention to details.
    Harold,I did not mean to imply you didn't pay attention to details..I said
    "Again close attention to details is a must for better modeling that leads to a highly detailed and greater looking layout" as a general comment aim at nobody in particular but as a general statement for all.. :D Sorry to offend you as that was not my intentions. :oops: :D
  13. hminky
    hminky Member
  14. MasonJar
    I was going to say that it looks like an old gravel pit. Having read the history (at the link provided above) it is indeed a "man-made" lake, created by excavating the overburden of soil and sand. The "environmental committment" is a bit of a joke in my opinion, as old gravel pits redeveloped as housing almost always leads to groundwater pollution and associated problems for the environment and residents' previously "pristine" wells... The water that is in the lake is the same water that is in the tap...
  15. Chessie6459
    Chessie6459 Gauge Oldtimer
    Harold, the silver balloon sure makes some nice water. :thumb: :thumb: :thumb:
