Mixing Engines
Discussion in 'Getting Started' started by Cannonball, May 4, 2007.
  1. IAIS 604
    IAIS 604 Member
    Mixing locos was the norm with the Rock Island - so much so that a photo of three MUed GP38-2s was labeled as "unusual" !
    GP38-2 MUed with either a GP7, SD40-2, GP40, or a U25B !!!
  2. Cannonball
    Wow.... this has turned into a much deeper discussion than I thought it would.
  3. 60103
    If you want a lot of examples in railroading, just ask if "something" never happened.
    For a while Model Railroader ran a column called "There's a prototype for everything" which was pictures of all the things that modellers are told never to do.
  4. Cannonball
    Really, all I wanted to know is if I was going to look silly running a U36-B with an EMD-18. :D
    I'd like to see those articles though.
  5. Jim Krause
    Jim Krause Active Member
    If you go back to the transition era, there was a lot of steam-diesel helpers and diesel -steam. but technically they wern't MU'ed since there was a crew in each type of loco with independent control.
  6. Cannonball
    They're both diesel
  7. Jim Krause
    Cannonball: Diesel helpers on steam powered trains.
    Steam helpers on diesel powered trains.
  8. Cannonball
    OK, I got that from your first post but what does that have to do with running a U36-B and an EMD-18? :confused:
    Or were you just bringing up the fact that steam and diesel could be mixed on a transition era layout and I totally misintrupreted your intent?
  9. Russ Bellinis
    Russ Bellinis Active Member
    Here in So Cal a favorite consist with the local switch crews on the BNSF was a U23b mu'd with a Topeka cab chop nose Gp-9. They found the U23b had a lot of low end "grunt" to get things moving and the Gp-9 had good cruising speed to keep things moving once started.
  10. Triplex
    Triplex Active Member
    A U36B and a GP18 could run together as easily as any other engines. The U36B does have twice the HP/axle, so it's obviously designed for much faster service - but engines certainly aren't always used for what they're designed for.
    RailPictures.Net Photo » CSX Transportation (CSXT) GE U36B A U36B/GP40?/U18B/GP40? consist. The same sort of horsepower mismatch.
  11. Cannonball
  12. Triplex
    Look at the telephone poles and the radio mast. It's a banked curve.
  13. NP 1364
    NP 1364 New Member
    MU locomotives
    844, left, and 4449, right, both have MU control boxes, next to the speed recorders, for useing diesels as helpers as trailing units only.
    The box above the MU unit is the train radio on 4449 and the "FRED" unit on top of that on 4449 while 844 has its "FRED" on top of the speed recorder and its train radio is over the engineers head
  14. Cannonball
    That second one needs a few more valves.
  15. doctorwayne
    doctorwayne Active Member
    Hummph!:confused: No wonder steam gave way to internal combustion: they had an infinitely variable transmission years before the automotive industry, but hung the "gas pedal" from the ceiling, there's neither tachometer nor manifold pressure gauge amongst all that instrumentation, and not much in the way of driver safety features, either. Heck, there's not even a padded dash, never mind airbags! :eek:
  16. NP 1364
    NP 1364 New Member
    You cant see it but, there is a manifold gauge (steam chest back pressure gauge) and the air brakes are of the automatic trainbrake kind.
    And its fuel injected!
  17. Kanawha
    Kanawha Member
    I've even seen Norfolk Southern units way out here in AZ.
  18. Pitchwife
    Pitchwife Dreamer
    Looks like they just grab whatever is on hand and go for it. :mrgreen: :mrgreen:
