M4A4 Sherman VC Firefly, Halinski 1:25
snake7
426
1,172
93
46
Israel
Thanks guys!
First of all - don't forget part 147, i almost did :)
I was little afraid about this tabs part with curved edges.
But if you plane wisely - it can go easy.
I decided to glue wall 150a/b to main part and then shape the tabs and the skin(150). Tried several times to assemble together without glue and it went well.
Tabs set exactly on wall curved edge. The curved part skin sits on, gave me right shape and i glued tabs to wall edge.
Assembled side bumps and interior skins and finished with lots of rivet heads.
In reality they replaced whole unit so everything was on rivets.
Transmission unit is ready!
snake7
426
1,172
93
46
Israel
Thank you Boris and Rhaven Blaack
I continue with inner parts of transmission unit.
The assembling was a joy, probably because of thoughtful design and white parts that almost don't need edge coloring :)
First of all differential carrier panel with steering brakes covers
Then were assembled all the levers that operated steering brakes and differential breathers.
Pay attention to engineering solution to transfer power to right steering brake by means of fat shaft and double lever.
A lot of small parts, but everything connected nice.
And parts are glued to place
I will connect roads to steering levers in later stage, when driving chair plate will be mounted
Tried dry fit panel into transmission unit
9,560
The precision of your work is astounding. ;)
snake7
426
1,172
93
46
Israel
Thank you Boris and Zathros!
I continue with gearbox.
Assembling was a joy, despite a few fiddling parts at the end.
This are all the parts. I love how designer attempted to group together most of unit parts, so the assembler will not search for them all over this huge book.
And first comes the gear box itself
Next is the engine generator cover
And last are shift mechanism with shift lever and universal joint assembly
I wanted to assemble all units as in drawings and then glue together, but as you see in picture above, i decided to leave some parts no glued and do it on main unit later. That gave me more freedom to adjust and glue easily
9,560
If you Photoshoped these pats of wooden pallets in a parking lot, I would think someone took apart a tank and were selling it's components! :)
  • Haha
Reactions: snake7
snake7
426
1,172
93
46
Israel
That's the amazing detalization of this model, taken to the maximum of 1:25 scale. I can't describe in words the joy I get building on such level.
The downside - every other model after this will feel like a toy
Reactions: zathros
12,393
That's marvellous! The cleanness and crispness of your work is remarkable. :)
Reactions: snake7
9,560
The downside - every other model after this will feel like toy
It's your skill plus the design. I could see this model being put together horribly. You put in the extra touches that made it the model as we see it now. ;)
Reactions: snake7
snake7
426
1,172
93
46
Israel
Thanks again
Well, gearbox is finished, so it's time to assemble all together
Gearbox to differential carrier and then to powertrain
Here you can see, that gearbox seats a little angled, that because on the other side engine axcell is higher
Fast assembling of driveshaft and then, finally, powertrain connected to the hall!
9,560
Fantastic!! That's one beefy differential!! :)
Reactions: snake7
snake7
426
1,172
93
46
Israel
Thank you mates :)
As i ended to join powertrain to hall, i returned to instructions continue to fill the interior.
Next are air filters. They located inside main hall and connected with tubes to the engine.
I decided to to join the tubes on site, for better match.
Also assembled driveshaft cover
And glued everything in place.
Yes, driveshaft disappeared completely under the cover, but you and I know
that it is there and connects engine to gearbox, like it should ;)
As i assumed, i was in need to adjust a little the length of the tubes, but eventually they connected well.
9,560
I'm really at a loss of words. This is really an beautifully executed model. ;)
Reactions: snake7
