M4A4 Sherman VC Firefly, Halinski 1:25
snake7
425
1,168
93
46
Israel
Truly Incredible. Those wire pieces are perfect. the aerials look good, but a thinner would be more to scale I think. Have you tried stretched sprue? You can get crazy thin but still stiff, segments using that method.
Thanks for suggestion, Micha.
In a matter of fact I did them exactly by drawing scale: 0.6 mm for aerial A (the long one) and 0.5 mm for aerial B.
With WS19 radio set aerials were pretty sick. I checked data about real thickness of this rod and it was about 13 mm, so in scale of 1:25 it's close. :)
micahrogers
3,773
4,639
Shannon GA
I know it, but knowing and seeing are different.... I'm more of a "build what I see" and not a build as it is.... still great work, and glad to see your shrink ray is still working.
snake7
425
1,168
93
46
Israel
Thank you all!
Before i turn to almighty 17-pounder, last detail was attached - storage box.
mijob
Tie designer
3,188
5,397
95
Netherlands
Everything you have made is breath taken, i dont have any words left to describe this build.
You are a gifted builder. Thanks for sharing and all the explanetion you have done.
snake7
425
1,168
93
46
Israel
Thank you, thank you, thank you. Trying my best :)
First part of the gun is semi-automatic breech block
It has interesting power structure and consists of several subparts:
breech block, connecting ears and breech lock
Ready
Notice yellow cylinder that houses spring that actuates semi-automatic breech
snake7
425
1,168
93
46
Israel
After another small vacation, back to work
Firing chamber with recoil cylinders
Complex 3d shape and so power structure
Now casing with mount axels
Was in need to cut hole in tight scrolled tube for MG, without micro drill.
Didn't know how to approach it, but eventually just did it with AK-4 craft knife with long 30 degrees blade. Just inserted wire inside this scrolled tube, so it will not collapse, and cut it slowly and gently on each side
Finally, some mount point for recoil guard
And everything assembled together
