M4A4 Sherman VC Firefly, Halinski 1:25
snake7
434
1,194
93
46
Israel
Thanks Boris!
Front hatch towers assemble. Another thing that i met for first time - fragmented power frame. :rolleyes:
I glued it first to inner skin, then skin to top and then outer skin.
Also there is another cushion inside + locking mechanism.
Couple of strips frame edges of hatch
Towers connected well to the body, no adjustments needed. :)
snake7
434
1,194
93
46
Israel
A little progress
Did the bow machine gun hole that is sealed.
The reason is - on Firefly there was room shortage for all the rounds for bigger gun, so the decided to cancel co-driver's place and put more rounds racks there and of course removed machine gun and sealed the hole.
Also auxiliary antenna mount casting. This was a little hard to assemble, because of complex shape. I did inner part step by step on the armor itself and outer part standalone and then glued it on armor.
I assume here is also a little mistake in design, because i was in need to adjust it in some parts, but maybe it's just me.:)
snake7
434
1,194
93
46
Israel
Thanks Rhaven
Some last bits of internal compartment:
  • 2 air vents, nothing special
  • 2 direct vision slots for driver and co-driver. Those could be popped up from openings outside
  • Big shelf for storing protective driver's hood. This could be attached to the hatch above driver and was made from canvas
  • Internal lights box with switches
That is the end with all internal parts!
snake7
434
1,194
93
46
Israel
Maintenance hatches covers and one for radiator fan.
Also couple of reinforcement hollow bars to strengthen hull floor
Here you can see my method to work with thin frame or ring.
First i cut only inner perimeter and then glued the cover on it. It gives easy holding and adjustments. And then i cut outer perimeter and cover with frame is ready.
Everything glued in place and bottom of a hull is finished.
snake7
434
1,194
93
46
Israel
And here i start another big stage in the model - suspension+wheels+tracks!
Tracks already done and waiting aside, so it's a half of assembling... Actually it's a half of whole model, if you count by parts ;)
I started with drive shaft casing.
Spend 2 evenings to assemble those and in the end they will be all covered with sprockets. Halinski defined next level of "no shortcuts" :D
Fenders and casings are attached to their places
9,599
The amazement continues. :)
snake7
434
1,194
93
46
Israel
Thanks Zathros
For any of you, who wondered what are those ribs on drum casing - those are reinforcing ribs, so the casing won't band under tension power of moving track.
Thanks for this info to fellow comrade on local forum.
And i continue with front sprockets.
Those are with interesting shape and given in two types, as you can see on second photo. So don't do a mistake and cut them all, you need only eight.
After assembling them i connected a little chain of tracks to see how it seets on sprocket - looks good.
Dry fitted them in place. Will glue in later stage, when chain will be put on.
mijob
Tie designer
3,249
5,493
95
Netherlands
:bowdown: This is realy next level building. How is it possible to get those pretty cut lines. Everything is crisp and clear.
You are a master builder. thumbsup
Reactions: zathros and snake7
9,599
Superb. The tracks section mated to the sprocket assembly was just excellent in fit, and looks, it just can't be done any better. :)
Reactions: snake7
snake7
434
1,194
93
46
Israel
Next are idlers.
They very similar to roadwheels, just bigger. So now it was "training on cats" and later i'll must to build 14 more.
All parts are cut
And this is a middle stage of assembling, so you will see how i decided to put together parts.
You need to pay attention to the axes. They rolled on different diameter and and intended to different sides - one to idler and other to tension mechanism.
Also disks are a little bit different on both sides of idler and as a result they have different numbering.
Two idlers are done
Dry fit on to the tension mechanism. Will not glue it in this stage, so i can adjust tracks tension... like on real tank :)
9,599
When you see the parts assembled, the whole things looks like it weighs a few tons!! :)
  • Haha
Reactions: mijob and snake7
