looking for an idea - wire mesh strainers
Discussion in 'Getting Started' started by rsn48, Mar 10, 2007.
  1. rsn48
    rsn48 Member
    A friend of mine turned me on to river silt as a base through out the layout, nothing like dirt to represent dirt. Now before I have posts warning me of impending doom using the river silt, a friend of mine has had his on his layout for 6 years now and it is working fine. Yes I not only baked it but froze it for a week as well, yes I ran a magnet over it, and then did a magical chant just to make sure.sign1
    Now here's my request, I'm laying this silt on the layout as a dirt base but the usual kitchen sifters don't quite sift the silt fine enough for N scale, some slightly "larger" pieces affect the look visually. Does anyone have an idea for a "finer" mesh, to sift the river silt yet another time>
  2. jambo101
    jambo101 Member
    Most earth i;ve seen comes kinda lumpy but if you dont like lumps a Blender or food processer will eliminate those lumps..Dont tell the wife.
  3. MadHatter
    MadHatter Charging at full tilt.
    Use a tea strainer
  4. Torpedo
    Torpedo Member
    Beat me to it.
    Check out a kitchen supply store for a wide selection. Also, don't forget window screen material.
  5. Cannonball
    window screen
  6. DougF
    DougF New Member
    A long time ago I bought a multi layer strainer that has progressivly finer screens as the material drops through it at the aquarium shop. It is used for grading the flake type food to finer material for use in feeding just hatched young up to adult size.
    I have no idea what such a unit would cost now as I have had mine over thirty years.
  7. joesho
    joesho Member
    im in ho,and ive used dirt for my whole layout,works fine!
  8. rsn48
    rsn48 Member
    River silt is slightly different than your average dirt out from the woods or back yard. By nature it is already some what fine with no clumping, the colour is uniform and generally lighter in colour than regular dirt.
    I definitely will try the tea strainer and I'll check out the pet store as well.
  9. Pitchwife
    Pitchwife Dreamer
    How about a flour sifter? The kind with the pump handle that stirs the flour around to break up clumps. :thumb: :thumb:
  10. Relic
    Relic Member
    Check out the great Canadian Dollar Store, they should have different strainers, yeah for a buck apeace.
  11. trainman4
    trainman4 Member
    Price check on isle four.lol
  12. rsn48
    rsn48 Member
    I tried out a tea strainer last night and it worked well. :thumb: I used a flour sifter first but for N scale the results were still too large; the tea strainer took it down a notch. I kept the left over slightly larger sand (silt) as I decided it might work really well as siding ballast, looking distinctively different from the mainline ballast I have purchased. :wave:
  13. woodone
    woodone Member
    Sift your dry dirt into a small jar ( old baby food) then strech some old panty hose over the opening, don't pull it too tight. Pulling too tight will open the mesh wider. Install a rubber band to hold the streched fabric onto the jar. Shake out your dirt, it will be very fine.
    I have done this many times, make good dirt very fine.
  14. rsn48
    rsn48 Member
    Woodone, I hadn't thought of old nylon hose, I'll give it a try; sounds like a good idea, but it must take forever to sift the sand; it did with the tea strainer. I would have three levels of silt if I do that: 1) flour sifter 2) tea sifter 3) nylon hose sifter; I would keep all three for use on the layout. I'm kicking my self now for throwing out the siftings when I used the flour sifter, it seems to me the different levels would work well in a "river setting."
  15. woodone
    woodone Member
    Oh yes , you need to sift the dirt through several sizes of screen(panty hose) or what ever. Star with a course sifter then got to a finer one and so on. I use 4 sizes before I go to the panty hose. The panty hose will make very fine dirt, and yes it comes out very slow, but it is very good at making the dirt look very realistic. One thing you might try is silk screen material, it is a cloth they use for making prints. You can get some large opening material, and make up some sifting screens. I have not tried that, but have thought about using that material for screens.
  16. MasonJar
    I have also seen plastic screen sifters at the dollar store - they seem to be a finer mesh than the standard wire mesh ones.
