Logging / Shay Layout Update
Discussion in 'N / Z Scale Model Trains' started by Brewer, May 8, 2005.
  1. Brewer
    Brewer Member
    Well, the track is down. I am about 75% done with wiring the blocks. Next is the control panel. I've been doing a lot of filing to get the trains to run smoothly. I was not a fan of the Atlas track going in, but chose it for economic reasons.
    Here's a few pics...
    The overall layout:
    Side view:
    The wiring spaghetti bowl:
    The good news is that everything is working so far and the trains can handle the grade at Cardiac Hill. The road rules include 40' max car length on mainline and yards and 30' logging cars on Disston Logging Branch. The Shay can only handle two cars on the logging branch at a time due to the length of the spur at the switchback (upper left part of plan) but could drag 3 loaded cars up if not for the siding length issue. So far, so good.
  2. Brewer
    Brewer Member
    The shay and two empties crossing the (future) trestle
    The shay switching Disston swapping empties for loaded log cars.
    GP-9 torpedo tube dragging some logging cars into Cottage Grove yard. The Geep can only switch one log car on the Disston branch at a time due to the short length of the switchback track.
  3. Brewer
    Brewer Member
    This has been a fun project so far. If you take your time with the track, you can get away with some pretty severe radius curves. Just stay away from anything 40'+ or anything with six wheeled trucks.
    The cost to build a small layout is very reasonable and the "bang for the buck" is there. If you have been hesitating to get into MRR due to lack of space, this sort of project might be up your alley.
    I'm glad to be back in the hobby!
  4. Livesteam
    Livesteam Member
    It looks really nice, how many shay's do you have?
  5. Brewer
    Brewer Member
    Just one. But that can always change... ;)
  6. Matthyro
    Matthyro Will always be re-membered
    Great progress Brewer. Looking forward to your progress. If yours is like mine, that little shay runs like a dream.
  7. Brewer
    Brewer Member
    Thanks. Yeah, the Shay's very smooth considering all that's going on down there with the drivetrain!
  8. Waldbahner
    Waldbahner Member
    Looks great !
    I still can't wait to get my Shay...
  9. Livesteam
    Livesteam Member
    I want to get a shay now too.Is that the tightest radius of curves for N scale?
  10. Brewer
    Brewer Member
    Just a bit over 8"
  11. Livesteam
    Livesteam Member
    i really like that GP-9 too are you planning on getting any other kinds of cars?
  12. Brewer
    Brewer Member
    <quote>i really like that GP-9 too are you planning on getting any other kinds of cars?</quote>
    I like the Geep, too! A killer deal on ebay ($39). Runs smooth and all I had to do was change out the couplers.
    As far as other cars, a few SP/UP/SPS 40' metal box cars, a few steel end wood side box cars, and one car that violates the 40' rule: a 50' troop sleeper for limited passenger service up the logging branch. It's similar to a locally made passenger car run on the prototype OSE.
    A fun project, so far...
  13. bubs
    bubs New Member
    what is the overall size of the layout?
  14. Tileguy
    Tileguy Member
    Looking Great Brewer.Nice wiring job.much cleaner than i have managed in the past.I'll take a lesson here ;)
    You are a much cleaner modeler than i am ,in fact, I only see one line on that plywood that looks like it doesnt belong. I generally end up with multicolors running all over the place :D
    When i laid my mini i was also amazed at how tight a radius you could get away with for some Loco's.
    I have about 7 1/4" aprox radius on my inside curve(18 x 30 mini) and i can run through it with an Atlas RS-3 at speed.
    Like you said, no 6 wheel trucks.Never happen ;)
    The old time box cars(billboards) ore cars,beer can tanks all handle the tight radius quite well as long as you dont have to switch on the curve.
    As to track.Atlas is affordable and i'm not sure what troubles you had,but i found it to be frustrating when i first began laying it.(on retrospect i believe it was mostly because i was used to laying HO and this was a bit more finicky.)
    After you get a hundred feet and a dozen or so turnouts laid things begin to smooth out some.
    For most folks the Atlas is just so much easier to
    Once again, looking great.Its nice to see you progressing and at the point where you can operate if you want to!!
  15. Brewer
    Brewer Member
    Had to dig this up...
    Vital Statistics:
    Width - 42"
    Depth - 22"
    Lower loop radius - 9.25"
    Upper curve radius - 8.25"
