locomotive current draw
eric halpin
Eric Halpin
Nov 10, 2006
72
Perth, Ontario
I am setting up my layout and am running a Spectrum 2-8-0. What I am wondering is, if I am straining the locomotive motor by running up to 18 mixed freight cars! At an average weight of at least 3.5 oz/car x 18 = almost 4 lbs. dead weight to drag. The loco seems to run just fine even up a short 2% grade, but I don't want to burn out the motor! Comments?
Thanks
Eric.
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
Before traction tires, we had the rule that if you held the back coupler and turned the power up the wheels should spin. If the wheels spin or the train moves, you won't burn the motor out. It's when you turn the power up and the wheels don't turn that the motor's in danger.
e-paw
200
saylorsburg pa
the motor should draw no more than an amp. touch it every so often to see if it is hot. if its to hot, drop a few cars. you can cook it if it stays cool
doctorwayne
3,516
Canada, eh?
This is good advice, and a simple test that anyone can perform. The Bachmann 2-8-0s are strong pullers, but even the Athearn 2-8-2, a notoriously poor puller, has a robust motor. While trying to determine the best way to improve its performance, I added a weight made from sheet lead, which I draped over the boiler like a saddle: it's too bad that there's insufficient room inside the boiler for this amount of weight, as the pulling power was increased tremendously, yet the loco was still able to slip the drivers when physically restrained from moving. The lead saddle weighed 22 ounces!:thumb: :thumb:
Wayne
GN.2-6-8-0
150
Glendale AZ.
Make that 1/2 amp. any locomotive drawing over 3/4 amp has a problem somewhere.
toptrain1
940
576
93
New Jersey
That 1/2 amp is good for a loco not working to hard. A fully loaded loco even with the best of can motors will pull a amp.
