Layout as Furnature
Discussion in 'N / Z Scale Model Trains' started by MinnMonkey, May 2, 2006.
  1. MinnMonkey
    MinnMonkey Member
    I am moving to a larger condo, however the available space for my layout will be smaller.
    The room it will go in is 9'x11'. My layout is basically 3'x6'. This room will also be a den, and spare bedroom so I need to make the most of the space.
    I am wondering what others have done to make thier layouts more attractive from the ground up.
    The only requirement I have is that is needs to be somewhat movable. I am not going to be moving it around the house, but it would be nice to pull out when I am working on it and push in a corner when I have guests over.
    Also, storage underneath would be a a huge plus.
  2. TrainNut
    TrainNut Ditat Deus
    Have I got the perfect solution for you! My layout is 3'x4', easily movable, attractive from the ground up, has storage underneath and doubles as a functional table so that you don't have to push it in a corner when guests come over!
    I know, I know... not quite what you were thinking?
  3. MinnMonkey
    MinnMonkey Member
    I was actually thinking of that, but 3x6 is a huge coffee table.
  4. glenn railey
    glenn railey Member
    Is that Z or N scale. It has definite possibilities.
  5. shaygetz
    shaygetz Active Member
    Mine is 43" x 60". I am drawing up a wall hung case that will allow it to be flipped down for home ops or used to carry it to shows. When hung in the dining room, it will have a removable cork/dry erase board so that my beloved can use it for home schooling our little ones.
  6. MilesWestern
    MilesWestern Active Member
    I have one of those "coffee tableau" layouts, and I'm in the processes of rebuilding mine!
    Say...shaygetz, what's on the "menu" curriculum? Readin' Writin' 'Rithmatic or Reading Wabash and Rock Island? :confused: :D
  7. TrainNut
    TrainNut Ditat Deus
    I was thinking of doing the same thing to a Dining room table. Haven't worked out the logistics yet and still have to find a suitable table but I think it has definite possibilities.
  8. sputnik
    sputnik Member
    Didn't we see a series of articles in one of the magazines where someone put a Z scale figure eight (large, well-scenicked figure eight, no toyish stuff). in the underside of a dining room table. The result was very artistic and modern.
  9. LoudMusic
    LoudMusic Member
    Another thread got me searching the forum. This I gotta see! A layout in a dining table would be perfect! Multi-purpose furniture makes so much sense - like a hide-a-bed (sleeper sofa) couch, or a night stand dog kennel.
  10. jetrock
    jetrock Member
    I have seen a lot of N scale coffee-table layouts (you can do one in 2x4 feet, which is a small coffee table, or more in 30"x6 feet) and HO scale trolley layouts (sharp trolley curves let them be almost as small as N scale layouts.)
  11. Papa Bear
    Papa Bear Member
    I like to paint the fascia on my layouts to give them a finished look. A curtain around the base can hide the legs and any boxes you might store under the layout. You could also use some ready-made cabinets or roll-away carts, although they are more expensive.
    I built a cover for my 2' x 2' layout. It keeps the four-footed railfans at a safe distance and helps keep "stuff" from accumulating on it.
    With the right accent colors, you can... Uh oh! I better stop - I'm starting to sound like Martha Stewart!:rolleyes:
