Kato Truck - SD40-2
Discussion in 'N / Z Scale Model Trains' started by ILCEN, Dec 28, 2004.
  1. ILCEN
    ILCEN Member
    I accidently took off one of the trucks on a Kato SD40-2. I have no idea how to reattach. When the truck came off there is two additional pieces, both tiny little black plastic pieces.
    There doesn't appear to be anything to lock the trucks into, I have no idea what was holding the truck in the frame.
    Any ideas? Thanks!
  2. sschaer
    sschaer Member
    if these two tiny black pieces are separate from the truck then you broke off the tabs which hold the truck in place. in that case you have to order a new one.
  3. ILCEN
    ILCEN Member
    Thanks. I ordered a new one from KatoUSA. I didn't see anyone else who carried them. The Kato trucks don't seem to pop in and out the as easily as the Atlas or LL ones.
    Does anyone know if the Kato trucks are designed to pop straight out or are they suppose to be twisted somehow?
  4. SD90
    SD90 Active Member
    You mean fall out like the Atlas trucks!
  5. ILCEN
    ILCEN Member
    Yes, the Atlas trucks can come off when you don't want them. I'm wondering though if the Kato trucks are designed to be pulled straight out.
  6. sschaer
    sschaer Member
    nope. neither straight nor twisted. kato trucks are not designed to be pulled out. you need to loosen the screws which hold the frames together.spread the frame a bit and the trucks will come out. if you simply pull you will break these tabs again.
    as mike said, atlas locos occasionally drop a truck. when a loco takes a dive onto the floor the atlas truck will pop out and can be remounted easily. kato trucks usually need to be replaced after.
  7. ILCEN
    ILCEN Member
    Thanks! I see the l screw and little nut on each end of the frame. I'm pretty sure I understand how to install the new truck now!
