Kadee couplers on Athearn SD40-2's?
Discussion in 'HO Scale Model Trains' started by Seaboard, Jan 7, 2007.
  1. Seaboard
    Seaboard Member
    Hi all, I have a pair of Athearn SD40-2s that have the removable coupler boxes and I was wondering if there was a way or is it possible to put Kadee coupler boxes were the athearn ones go.
    any suggestions or ideas will be appreciated.
  2. Jim Krause
    Jim Krause Active Member
    Our club just ordered two Athearn SD40's last September. I replaced the stock couplers with Kadee #5's without changing the coupler pockets. After re-reading your post, maybe you have an older version with different coupler's. Kadee has a website that I believe lists which couplers go with most of the major manufacturers loco's.
  3. LongIslandTom
    LongIslandTom Member
    Athearn's SD40-2s have several different vintages...
    Mine are the old Blue-Box SD40-2s with the coupler mounting tab positioned too low, and they required underset #47 Kadee couplers. I had to drill #50 holes on the coupler-mounting tabs and tap them for 2-56 screws to mount the Kadee #47s.
    If you have a newer-vintage Athearn SD40-2, it might have the coupler mount at the right height to take a standard #5 Kadee.
  4. Seaboard
    Seaboard Member
    They looked like they would fit, I just didn't know if they would fit in the coupler pockets before I went out and bought em. Thanks for the help :)
  5. Seaboard
    Seaboard Member
    Tom, I had recently bought a new SD40-2 not to long ago, it did come in a blue box. It has the diesel engine on the front if that matters. And my other one is older but it has the same. There pretty new.
  6. LongIslandTom
    Sounds to me like you got the ones that has the coupler mount tab at the right height. As Jim says, the Kadee #5s should work on your loco. Give it a shot. :thumb:
  7. Seaboard
    Seaboard Member
    Thanks Tom, I'll give them a try:thumb:
  8. jeffrey-wimberl
    jeffrey-wimberl Active Member
    I have two Athearn BB SD40-2's and have #5's on both of them.
  9. shaygetz
    shaygetz Active Member
    The #5s were a drop in fit in the one I just got:thumb:
  10. Seaboard
    Seaboard Member
    I just got the new #5's on my Two SD40-2's and they work perfectly:thumb:
