Jedi ETA-2 by Paper-Replika
vbsargent
175
3
MD, USA
The mission: Scale Paper-Replika's Jedi ETA-2 up 157% and build with interior by Tomasz Bąk also available on Paper-Replika.com. Construct with opening clear canopy, and possibly hinged wing flaps. Create a recessed port for R2D2. Make sturdy enough to be played with by a 4 year old.
Finish by said (almost) 4 year old's 4th birthday on May 14th.
I had originally planned to scale up the Republic Attack Gunship, but seeing that it would be between 3 and 4 feet in length when properly scaled up, I realized that I had nowhere near enough time. So that will have to be longer term, maybe Christmas.
So I scaled the templates up, and had to rearrange them and modify pieces to fit on the 8.5x11" stock that I have. I'll be using 65# card stock with 1mm matte board or 3mm Sintra (a PVC foam board) depending on how much reinforcement is needed in each given area.
I will upload some pics as soon as I get them off the camera.
vbsargent
dnalor
917
186
Belgium Europe
I will be watching this build, it's fun ship
And i hope for you that it will survive a 4 year old and not crash with the first flight :)
vbsargent
175
3
MD, USA
First set of pics ... nothing much, just the resized, reorganized and crammed together pieces.
The complete enlarged model on top, and the almost stock printout on bottom (Ok, printed at 94% to fit 8.5x11). And yes, I will be building both scales, one for him,and one for me. :mrgreen:
The main body/cockpit base. This really shows the difference in scale.
More scale pics, showing the cockpit compartment.
And one more scale pic. Poor R2 . . . . looks like he blew a circuit!
Will post more progress pics when I get them downloaded on my computer.
Szdfan
48
I'd be interested to hear how you will make the model sturdy enough for young hands.
Inv8r_timmy
13
Canada
Not to play devil`s advocate or anything, but you know the eta2 is available from TRU for like $25, right :) I`m doing something similar and working on an ISD for a 7 year old birthday on the 8th of May, myself. I`m thinking maybe brush-on resin, as if you were going to do a large pep-armor, but without the step where you lay in FG matting. I`m trying something similar for components of uhu02`s greedo killer I`m using to mod a metal C96 I`ve got. Problem might be that just resin may be too brittle for a 4 year old.
F131
F131
Mar 27, 2008
420
4
Minneapolis, MN
Agreed. This will be amazing!:thumb:
I need one of you smart folks to explain how to increase model scale. I would love to re-build ARC-170, but to at least twice the size of the original (which is pretty small).
I use Photoshop because when you double up the sizes, you have to rearrange the parts.
You want the ARC 170, I'd have to look at that file to see. :)
9,892
Here are two models from www.paper-replika.com:
http://paper-replika.com/index.php?...id=432:arc-170-fighter&catid=40&Itemid=200144
http://paper-replika.com/index.php?...-170-clone-war-version&catid=40&Itemid=200144
As for resizing, you can always go to your local Kinko's, or staple's (or any other print shop), and ask them to resize the file and print it out on what ever paper you want it on.
Good luck and enjoy.
ASC Mclaren
884
369
Western Washington
Very cool! Are you going for 1:20 or 1:18? I scaled up the interior and modified it for my 1:18 Thunderfighter build. I am interested to see how you will build the droid socket. I will be watching this!
vbsargent
175
3
MD, USA
@ Szdfan- I'm using PVC foam board (not foamcore), the PVC is used for making outdoor signs. It is a lightweight sturdy plastic.
@Inv8r_timmy- But if I purchased it, I couldn't say that I made it. :mrgreen: Plus, there is a lot more love involved in something that was made and not just purchased.
@ASC Mclaren- I figure it to be about 1/18. I used the R2 unit width as my barometer/measuring stick. Once I got the width correct, that was the scale.
Progress time!
Cockpit/hull base cut out and edged painted with 10x0 brush. These watercolors represent the best $3 spent on paper modeling:p
The Sintra base. Not as clean as I had hoped . . . plus a bit of skin left behind courtesy of Mr. CA Glue.
The front of the Sintra base.
The two together.
Grrrrrr ......
Well, not as clean as I had hoped. Some issues with the Sintra base, but not too objectionable, at least not so that a 4 year old would get upset about it.:rolleyes:
Apparently R2 is -VERY- protective about Anakin's ETA-2.
That's it for now, hopefully I'll get some decent progress tomorrow.
vbsargent
Reactions: d5j4vu
vbsargent
175
3
MD, USA
Forgot to get pics yesterday, so took pics of the past two days' work. Getting some progress in the cockpits, I may just go with mostly 2 layers laminated matte board plus the card. The large cockpit floor and rear bulkhead were done this way and it is THICK and sturdy. So far the builds are not as clean as I would have liked, but I don't think that will be detrimental to the overall pieces as they are meant to look extensively used in battle.
Here's pics:
This image has been resized. Click this bar to view the full image. The original image is sized 1024x947 and weights 145KB.
Floor of cockpit. You might notice some degradation in the color saturation between the smaller and larger pieces. This is due to having to convert all to jpegs then edit in Photoshop, then print. Next time I'll try to convert to PNGs.
BTW- the rear bulkhead is not attached as yet, they are just leaning up against each other.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x822 and weights 145KB.
More floor/bulkhead.
This image has been resized. Click this bar to view the full image. The original image is sized 1013x831 and weights 134KB.
And more . . . . .
This image has been resized. Click this bar to view the full image. The original image is sized 1023x552 and weights 75KB.
Sides of cockpits both large and small.
This image has been resized. Click this bar to view the full image. The original image is sized 1023x734 and weights 192KB.
Detail shots
This image has been resized. Click this bar to view the full image. The original image is sized 1023x674 and weights 118KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x668 and weights 195KB.
It's hard to tell, but the little red dots are about 1 mm in diameter on the smaller model.
Hopefully I'll get more done on both tomorrow and some more detailed progress pics.
dnalor
917
186
Belgium Europe
Looks great... thumbs up..
I like it..a large and small version.. :)
That is something i couldn't do..all that stuff is to small for my fingers...
Or i'm to novice in all this. :)
vbsargent
175
3
MD, USA
@ Rhaven Blaack- Thanks, the detail is from the cockpit on Paper-replika.com Looking at some of the specifics, I'm not sure that the model in the pics is actually from the templates presented. But it sure is nice having cockpit details!
@dnalor- Wait . . . . didn't you just finish a Falcon with lots of small fiddlin' details? And you are currently building a big ol' X-wing?sign1
dnalor
917
186
Belgium Europe
yep that's me :)
the falcon-dude that is building an x-wing :-D
But the falcon is :
Quote Luke Skywalker: a big piece of junk ....so that wasn't very hard to build :p
And the Xwing is Harder...it's a cleaner build..
I think it looks great!! I wish,and there may be, by just asking, a way to distribute the model at these larger sizes. It could save others time ad allow those who do not know how to do this the opportunity to build it. :)
