Is it possible to electrically isolate Bachmann ez tracks?
Discussion in 'HO Scale Model Trains' started by mikebalcos, Dec 24, 2008.
  1. mikebalcos
    mikebalcos Member
    I'd like to know if there is a way (preferrably cheap) to electrically isolate Bachmann ez tracks. My purpose is to make blocks out of them. It appears to me that ez track is designed for DCC. But I prefer to stay with DC.
  2. Trainiac77
    Trainiac77 Member
    I would just use a razor saw or dremel tool to cut the rail (and then a drop of CA to insure the rail doesn't move and short) and solder the wire leads to the joiners.
  3. Mountain Man
    Mountain Man Active Member
    But that would negate the attempt to isolate that section. The power feed should be to the isolated section by itself to maintain integrity. Wiring the joiners is the same as not cutting the track in the first place, since power will flow to both the isolated and connected block.
  4. GWoodle
    GWoodle Member
    The rail joiners may be just loose enough that you can swap them for some Atlas plastic (insulated) ones.
    AFAIK the turnouts are power routing. You may need to modify the tirnout to be sure both ends are lined correctly.
    There may finally be a book out about using EZtrak. Look in the Jan issue of RMC.
  5. ZeldaTheSwordsman
    ZeldaTheSwordsman Thomas Modeler
    Well, you can slip on plastic joiners at the ends of a block and include a power terminal track in the block. Plug that in and you're good to go.
  6. jeffrey-wimberl
    jeffrey-wimberl Active Member
    Getting the joiners off of EZ-Track is not a simple thing to do. What I do is to simply cut the rails with my Dremel rotary tool. The section can then be wired through a center-off DPDT switch for multi-cab control. My layout is all Z-Track. I cut the layout into 16 blocks using this method. I can use any block on DC or DCC (never both at once) with the simple flip of a switch, up for DCC, down for DC.
  7. ZeldaTheSwordsman
    It's easy if you have a firm grip(or needle-nosed pliers).
  8. mikebalcos
    mikebalcos Member
    Thanks, everyone. I liked the "Atlas plastic joiners replacement" approach. I've been using Atlas track for quick some time, and I would like to tryout those Bachmann tracks.
  9. smithvillebill
    smithvillebill New Member
    block wire
    9"power terminal with insulated gap item #44597
