Inside Kato switches...
Discussion in 'FAQs' started by csxengineer, Feb 7, 2004.
  1. csxengineer
    csxengineer Member
    I hate Kato's switchcontroller appearance. I opened the turnout and saw it is an electromagnet. Question: Is it a momentary switch like atlas, or is it okay to have power on constantly by using a simple toggle switch? It is 2 wires unlike atlas which uses three. Also, can I use 2 push buttons, but then, how would I change polarity? Help :rolleyes:
  2. cidchase
    cidchase Active Member
    Hi csx,
    You can use a DPDT Momentary (spring return to center)
    toggle switch. :)
    You can also use 2 buttons, provided they have both Normally
    Open (NO) and Normally Closed (NC) contacts on each button.:)
    I'm pretty sure you can't leave power applied continuously,
    someone correct me if I'm wrong.:sleeping:
    :thumb: :wave:
