I cann't understand the annotate in Polish, who could help me?
Discussion in 'International Modelers' started by paranoia, Jan 14, 2010.
  1. paranoia
    paranoia New Member
    I can only understand English and Chinese, and I have used GooGle Translate, but I sill don't understand some annotate:
    specifically s, k, kk, k+k, what are these mean?
    thank you!
  2. lehcyfer
    lehcyfer Member
    s - part is on normal paper - standard
    0,4 - glue on 0,4mm card
    0,5 - 0,5mm
    * - 1mm
    ** - 1,5mm
    *** - 2mm
    **** - 3mm
    D - made of wire
    k - glue on karton (I suppose that karton means the card the model is printed on)
    kk - glue on double karton
    P, L - right, left side
    the last five:
    - bend between the lines
    - glue inside a card - as marked
    - cut apart
    - shape of element seen from the side
    - glue using cyanoacrylic glue
  3. paranoia
    paranoia New Member
    Thank you so much! you have gave me a GREAT HELP!!
  4. lehcyfer
    lehcyfer Member
    You're welcome :)
  5. kanohidragon
    kanohidragon New Member
    Models from "Mały Modelarz"?
  6. lehcyfer
    lehcyfer Member
    No, it was some other publisher. Unfortunately the markings in Mały Modelarz vary from one designer to another and it's often important to read the instruction closely for parts can be for example not clearly marked for laminating while in instruction it's written - "laminate such and such part on such and such card".
    One has to see what the instruction says in that exact issue. If you have problem, scan the instruction and I'll do my best to help you with difficult parts.
