How do you change the color of Cut Lines?
GlueAndPaperGuy
I need me some green cut lines. Can that be done? I didn't see anything in the online docs. I loose the tab lines of the Shrek pattern I'm building. I've done color padding. I've suppresed the fold lines. I can't get that lst piece that would make it infinitly easier to score this thing.
12,361
Paint the edges with water colours or a marker. That always helps. If you use water / acrylic colours you will be able to mix and create a tone that comes pretty close to the one you need.
If you have a completely monochrome pattern you can print it on coloured paper which eliminates white edges automatically. :)
9,549
Another method would be to print out two models. One with lines, and then cut it out, and use those templates to put folding marks where you want them. Lots of work, but potentially, no lines, just some dots here and there, that give you a reference point for bending. ;)
