How close can you lay roadbed?
Discussion in 'HO Scale Model Trains' started by prodigy2k7, Dec 21, 2006.
  1. prodigy2k7
    prodigy2k7 Member
    I am curious of one thing, how close can you lay roadbed to each other (two tracks) without trains hitting each other, can they go right against each other? or is there a official or well known length that should be space between the bedding and tracks?
  2. zedob
    zedob Member
    Technically you can go down to 1-13/16", but most use no less than 2" between centers. I have a double crossover that is 2" on centers between the parallel tracks, so that's one of my gages.
    On curved track I let it range between 2-1/8 to 2-1/2, depending on the radii. The tighter the radius, the more clearance.
    I don't know the width of your roadbed material, but I would think that would self gage, edge to edge. Put two pieces side by side and measure center to center. if it's 2" or more, you're safe.
  3. prodigy2k7
    prodigy2k7 Member
    thanks, makes sense :)
  4. jbaakko
    jbaakko Active Member
    Mine was 2", but I added 1/2" between for that extra Five point switcher room.
  5. kitsune
    kitsune Member
    13 scale feet, just like the real world. It's tighter but I prefer the realistic width.
  6. Triplex
    Triplex Active Member
    Actually, I thought I heard that a number of real lines nowadays had been widened to 20' centers. (Incidentally, that scales to 1.5" in N, making N-Trak actually realistic!)
