How big of loco will make a 22" curve?
Oreboat
3
Muskegon, MI
The outer loop around my layout I am going to have no less then a 22" radius curves and #6 turnouts. How big of locomotive can I run with out derailing all the time? I'd like to be able to run some six axle engines if they will handle the turns. Also how big of a steam loco can I run? Thanks Bill
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
My SD80MAC can handle it. It looks ok, but it the pilots do hang out a bit. It doesn't effect operation though. most 6 axle diesels can handle it. I can't really think of any locomotive that can't. its the 80 foot railcars you need to watchout for.
I think most Steam locomotives can handle it, except for those with a long solid frame (2-10-4s, etc). In real life such locomotives would straighten out the rail if the radius was to tight. luckily for you, the models will only jump the tracks. However, i do not see any reason why a 2-10-4 couldn't handle it. usually the manufacturers will tell you what their model can handle. Articulateds ( Challengers, Big Boys, Alleghenies) should have no problem even on 18 radius, but they will look bizarre.
LongIslandTom
662
Long Island, NY
Most HO steam loco manufacturers actually use a pretty un-prototypical method to allow big steam locomotives with 5 driver axles get around 22" radius curves... They make the center driver wheels blind, i.e. the center driver wheels have no flanges. Don't know if they made provisions for you to swap in driver wheels with flanges if you do run big enough curves though.
Personally, I think small locomotives look better on small pikes with 22" curves anyway. :cool:
NYNH&H
166
I can run an Athearn Genesis Challenger and an Athearn RTR AC4400 on 19.5" curves. Ugly, but it works. I have had the AC4400 on the club modular layout with like 40" cruves. It looks MUCH better.
NYNH&H
166
They also double articlulate Big Boy and Challenger, so that they can get around 18" curves. They look bad, but run well on these sharp curves. The prototypes were single articulated, and scaled down to HO, the Big Boy would need a 40" radius MINIMUM if it were made prototypically.
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
they make one in brass like that. I think my Lionel Challenger has a provisions for making the second driver set stay in one spot for realistic running.
