Honey-I shrank the gondola-or I can't leave..
Discussion in 'HO Scale Model Trains' started by foulrift, May 29, 2008.
  1. foulrift
    foulrift Bob
    I picked up a 50' gondola the other day but being the type of person who can't leave well along deceided to shorten it to 40'.The only real issue I had was that supplied weightr was a fuzz too thick(Athearn kit).Instead I added styrene to underside until frame fit properly.I will compinsate for the missing weight bt adding a couple of steel coils that I have that are made of metal. It is now ready for paint. Bob
  2. TruckLover
    WOW sweet job Bob!!!
    What road name are you going to paint it?
  3. foulrift
    foulrift Bob
    Thanks Josh-Most of the current name-Golden West Service is still visible. The crew did a prety good job in preserving the name when the pieces were welded together so I think I'll just leave well enough alone.There are a few spots where I'll have to touch up the blue but I don't expect an exact match.I'll post new pics once it's out of the paint shop and I get it weathered etc.Thanks again-Bob
  4. RonP
    RonP Member of the WMRC
    Looks great Bob,
    Gotta find something to do instead of twiddling those thumbs huh ?
  5. nachoman
    nachoman Guest
    What was your motivation for shortening it? Is there a prootype you are trying to match, or do you just need shorter cars for the curves on your layout?
  6. foulrift
    foulrift Bob
    Ron-You guessed it.Due to other obligations it make take a little longer before I get the rest of the track and lumber that I need but I hope it won't be much longer then I can start to build.
    Kevin-just wanted a shorter car.My layout will be small and I'm going to be using Peco small radius turnouts and I thought 50' might be a little much so I had the crew get out the torches and have at it.Bob
  7. Russ Bellinis
    Russ Bellinis Active Member
    The blue on that car looks very close to AT&SF blue from a blue & yellow freight loco. AT&SF blue is probably readily available from your lhs, but if not Bangor & Aroostook (spelling?) blue is also close. The other possibility would be B&O dark blue. If I remember correctly B&O had a passenger scheme with dark & light blue bands. The same dark blue was used on their "cigar band" paint scheme.
