HO sidewalk thickness
Discussion in 'Getting Started' started by patgin, Apr 5, 2006.
  1. patgin
    patgin Member
    I would like to create HO sidewalk using styrene sheet. What is the best thickness to use?
  2. jetrock
    jetrock Member
    I generally use .040" sheets of styrene, personally I prefer the 1/2 inch or 1/3 inch squares (real streets vary widely.) I use .060" square styrene for the curbs, using sandpaper to round the outside corner a bit.
  3. patgin
    patgin Member
    How much millimeter are 0.40" ?
  4. Doc Holliday
    Doc Holliday Member
    Real sidewalks are typically 4" thick, which translate in HO scale to 0.0038' (.045") or 1.17 mm iffin my math is correct. Joint spacing is typically 10'-12' for construction joints and 4'-5' for score lines.
  5. babydot94513
    babydot94513 Member in training
    We have 6" curbs here. I was never any good at math so do not ask me to convert to millimeters.
    One thing to remember and may not be clear to all is that the thickness of a sidewalk slab is not the same as the height of the curb.
  6. ezdays
    ezdays Out AZ way
    You are correct. In N scale, I used .030" square styrene for my curbs, so my sidewalks are just as thick. In real life, sidwalks are poured 4" thick, but they are built up higher than the street with dirt and gravel. No one is going to know how thick your sidwalks are, just as long as they are even with the curb, that's what counts.
  7. cidchase
    cidchase Active Member
    To convert inches to millimeters, multiply the inch value by 25.4.
    In other words, 1 inch = 25.4 mm.
    0.040 in. = 1.016 mm (call it 1 mm)
    0.060 in. = 1.524 mm (call it 1.5 mm)
    You probably have a calculator included in your PC software (calc.exe).
