HO drop-in sections
Discussion in 'HO Scale Model Trains' started by papasmurf37, Dec 28, 2004.
  1. papasmurf37
    papasmurf37 Member
    Am constructing drop-in sections for our HO sectional layout. Is anyone here doing the same? TTFN.....Old Tom in NH :)
  2. RailRon
    RailRon Active Member
    Tom, do you think about structures to 'drop in' on the layout?
    If yes, perhaps this thread could help you.
    If no, could you give some more details?
  3. jetrock
    jetrock Member
    I'm planning on having a lift-out or swing-out or drop-down, but probably not a drop-in...tell us about it!
  4. papasmurf37
    papasmurf37 Member
    THANKS for the replies to my post!
    Basically, due to work commitments, my friend and I do not get together often enough to work on our present layout. Am making first 2'X4' drop-in section on 2" extruded foam slab. Peco TT, Atlas roundhouse and basic loco servicing facilities[coal/sand/
    water/diesel fuel/ashpit]on TT lead. Since we use hollow core doors with 2" of foam atop as the basic units of our sectional, portable[take to train shows]layout, we can insert the drop-ins anywhere we desire by pre-planning track/turnout locations. We're both ex-members of same HO modular club from several years ago. We did use some drop-in structures on that layout as some members wanted to have the ability to change trackside industries to make Operation sessions more diversified.
  5. spitfire
    spitfire Active Member
    Sounds like a great idea Tom!!!
  6. Russ Bellinis
    Russ Bellinis Active Member
    Great idea, Tom. Another use of drop ins to consider is it would be a neat way to change eras if you liked to run modern diesels one time, turn of the century steam the next, and late 40's at another time.
