hight...
NCMRailroad
90
Hi Everyone,
Need to wonder... My mainline is 16 feet in length (HO scale) and am planning on it being elevated. Just curious as to what the Maximum practical elevation would be at that length? (running steam)
Thanks to everyone that replies:thumb:
NCMRailroad
LoudMusic
620
If it was a continual climb the entire 16 feet (192 inches) it would be 3.84 inches up from where it started at a 2% grade.
4,501
Lakewood, Ca.
There would be no maximum elevation. If you are are talking about maximum grade, probably 3%. Model trains will pull 4%, but they won't pull much at that gradient, and coming down they tend to jerk. 2% is better. The % is the amount of rise in 100 units. If you are measuring in inches, 3% would be a 3 inch rise in elevation in 100 inches of travel, about a 3 inch elevation change in a distance of 8 feet 4 inches.
fsm1000
467
Coquitlam BC
fsm1000.googlepages.com
My shay can pull 11 ounces up 9% grade, That is two SMALL cars though.
My Porter 0-4-0 can only pull 3 ounces or one SMALL car.
For all practical purposes 3% should be your max with 2% something to shoot for preferably.
Just my opinion, hope it helps. :D
doctorwayne
3,516
Canada, eh?
Another thing to keep in mind is that curves will increase the effect of any grade. A locomotive that will just barely pull a train up a straight grade will not likely pull the same train up the same grade if the track is curved. And the sharper the curve, or the more curves that are included in the grade, the less that same loco will be able to pull.
Wayne
