Help!
paulf
8
2
I am working on a papermodel right now. The files are PDO and saved in pepakura viewer 4. I need to move some of the parts but i think i need to do that in pepakura designer 4 but don't know how. Can anyone help me?
12,361
Install Pepakura designer and right-click the PDO and choose "open with Pepakura Designer". Then you should be able to move parts - unless the creator has applied a password that prevents editing. In this case you could export the unfold as PDF and edit the pages with Gimp. ;)
Reactions: zathros
9,549
Yeah, what he said! :)
paulf
8
2
What is the particular model that you are working on and what is the issue that you are having?
It is the Gundam Astray Blue Frame Second Revision. I will attache 2 files so you can see the issue. One is the PDO instructions in Pepakura viewer 4 for the left and right Arm on the side that shows the parts unfolded there are some that are not on the pages that they need to be so the didn't get printed on the PDF templates and the other file is the PDO instructions for the shields as you can see where the unfolded parts are a couple of pages they are bunched together and need to be moved.
Reactions: Rhaven Blaack
9,917
If you can open the file in Pepakura Designer, you can rearrange the parts as you need them.
9,549
That picture is why I don't use anything by Pepakura. If you can open the file in it, you can get some idea how to make it, but if not, you're screwed. I guess you could take different screen grabs showing where the parts go, but what a pain in the but. My hats off to you guys who can make stuff with this, though virtually every model I have seen has no internal supports . There are some exceptional models too. My brain can't handle it though Good luck. I look forward to seeing what you make. Instead of rearranging parts, you could open it up in XNViewMP and just crop pages, which will cut into some parts, but keep on cropping the same amount, and eventually you will have the parts you need, with a bunch of superfluous stuff. Can't you import the pictures into pain and crop them, saving them the same size, (in ration) and end up with what you need? ;)
12,361
It is better to print the pages as PDF and then turn it into images. ;) Direct JPG export is not possible if you don't have a full license. I know what you mean but I think there are so many overlapping pieces that it could be impossibleto seprarate them.
spaceagent-9
Right Hand Man and Confidant
3,112
3,478
143
62
pheonix
If all else fails, take a screenshot and then cut out the parts with the lasso and paste them into MSPaint arranged in the order you want.
paulf
8
2
I don't have the payed version so i can't. Is there anyone that would be able to make the fixes for me if i provide them with the files?
9,917
paulf
8
2
That is odd. I just downloaded it and did not have to enter a key code.
The functions that i would need to fix my issues are all grayed out i think you need to buy a key to get all the functions. At this point i think i just have to use what i have and figure it out and i think the files are password protected and that is why if i try and open them in designer 4 it opens them in viewer.
9,549
You can Google keys for Pepakura Designer. There are only a few numbers they used I downloaded it, and it didn't even ask for a key. When I tried using it, I found it to unintuitive, and it just sits there as a Icon. :)
  • Haha
Reactions: mijob
12,361
I have a full license. Do you have a download link to the model file?
Reactions: mijob
9,549
Can't you save the ("PRT SCN") work to the Clipboard, the paste into "Paint"?
