Help with Building the Buck Rogers Thunderfighter
dirkpitt289
174
319
40
57
Hi guys
I'm currently building the Thunderfighter and need some assistance.
If you look at the instructions, you are suppose to place parts 38, 39, 40, 41. 42, 43 onto the top of part 37 in the following configuration (Pic 1). The problem I have is as seen in pic 2, the way 39 part actually sits on part 37. Part 39 and the other (Arrow 1) over hang the forward panel line (Arrow 2). Am I misreading this in some way?
You can see in the picture (Arrow 3) the parts sit behind the panel line
Should I cut the long legs back to the line (Arrow 4)
I hope i'm making sense
12,353
You have missed to fold the U-shaped piece back. The position of the part is correct but you have to fold the tip at the grey line to the inside and glue it to the back of the part. That is done to reinforce the parts and to texture the inside of it at the same time so that you see the vanilla colour when you look straight into the intakes.
This picture is taken from one of Rhaven's builds:
imag4818-jpg.137226
You can see how the sides are folded and glued back to the inside. I hope this helps. :)
Reactions: Rhaven Blaack
9,909
@dirkpitt289 If you would like, you are more than welcome to us my Detailed Thunder Fighter Project for reference to help and guide you through your build. The thread is 19 pages long with a plethora of added details and greebles to enhance the model as a whole.
If you have any questions or need additional clarification about anything that I have done, please feel free to contact me directly and I will do what I can to help you (or at least point you in the right direction.
