HELP new to DCC
Discussion in 'DCC & Electronics' started by jasbourre, Oct 4, 2006.
  1. jasbourre
    jasbourre Member
    I'm thinking of getting a DCC system for my layout. Can anyone recomand one to me.
    I look arround a little, (I don't know much about DCC) and found this one.
    It's a E-Z Command/DCC anyone use this one.
    I don't have any loco's with sound, all I want to do with it is move my trains (HO)
    Please help.
  2. rfmicro
    rfmicro Member
    I do not use this system myself, but from reviews on other forums the Bachmann E-Z Command/DCC is adequate for small layouts and for folks who just want to run a couple of trains. Most folks found fault with the included Diesel w/decoder, but you get what you pay for. Programming the decoder is limited to numbers 1-9.
    It sounds like it should fit your requirement and the prices are around $100.00.
  3. MasonJar
    Why do you want to go to DCC? Those reason(s) should be taken into account when you select the system you buy. There are a few options around $100, several more at under $200, and many at $200++.
    The Bachmann system you see there has only one advantage over a DCC power pack - it can address up to 9 locos, so you do not need (electrical) blocks. But it has no capacity to do sound (which you say you don't want - right now ;)), no walk-around, no expandability, and no (direct) multiple loco control.
    I chose the Digitrax Zephyr because I wanted more advanced engine controls, including sound. THe unit is also compatible with any other Digitrax component for future expansion, it can handle multiple throttles, and it offers advanced programming capability with CV read. THe biggest advantage of choosing Digitrax though is that the majority of modellers in my area, and at the modular club, use Digitrax - any questions are easily resolved.
    Hope that helps.
  4. jasbourre
    jasbourre Member
    One of the reason is because I don't like to do wiring, and I won $400.00 playing ProLine.
    I'm thinking of the E-Z Command/DCC because my layout is not very big and the E-Z Command/DCC has the ability to be added onto.
  5. MasonJar
    I stand corrected - you can indeed expand the capacity of the system, according to the Bachmann web site.
    If your overriding consideration is cost, then this may be the solution for you. It is a basic system that will "move the trains". Do you plan on running more than one at a time? If so, you might want to consider the extra cost of additional throttles ("controllers") and whether the basic system's amp rating will be exceeded by what you want to run.
  6. Nomad
    Nomad Active Member
    I have the bachman E-Z command. On my first layout(a 4x12 double loop, no wye and no reverse loop) it worked great. To hook it up, all I did was unhook the dc, hook up the dcc, turn all the track switches on,and it worked great. I installed a decoder in a bachman spectrum. I did not buy the loco with the E-Z command. I am still building my new layout(went to a 6x12 in ho) so have not used it in a while. I think it's great for beginners like us.
  7. cidchase
    cidchase Active Member
    Hi jasbourre,:wave:
    This has been pointed out before, but the EZ Command will NOT program
    your decoder. If you need to change start voltage, speed steps, how
    the lights work, etc you will need a programmer or have it done for you
    by someone with a different controller. Probably with a Bachmann-supplied
    decoder in a Bachmann engine, it's all fne. :thumb: Just be aware of what
    you're getting! :) :) :) :)
  8. gcodori
    gcodori Member
    Just a heads up regarding not being able to program with ez dcc...
    You can build a programmer for your computer for about $15 in parts (priced at - cheap electronics). Can be built on vero board, no PCB etching needed.
    Use the windows program Prolok (free) to program. This programmer is an updated version of Digitrax's programmer, and works with Windows XP. You just need to change the language setting to english.
  9. Nazgul
    Nazgul Active Member
  10. biker_ray_pa
    biker_ray_pa New Member
    I would recommend the AtlasMaster system. It's small and expandable with a walkaround throttle available, it has a few functions and is more than adequate for a small layout. Later, if you want a better system, you can upgrade to a Lenz system and just swap command stations, as Atlas uses the Lenz XpressNet system. You'd even still be able to use your Atlas throttle if you wanted. That's how I did it.
  11. Mannix
    Mannix Member
    I purchased the Prodigy Express this past summer and I am very happy with it. I purchased it on the Internet for $109.99 so the price was right. That price included everything that I needed.
