Ground Throws
Discussion in 'FAQs' started by rockislandmike, May 9, 2002.
  1. rockislandmike
    rockislandmike Active Member
    Just perusing the spring savings catalogue from Walthers (just got it today in an order I received), and they're having a sale on Caboose Industries' operating sprung ground throws. Which I think would look pretty neat in some places.
    But I don't know whether I need .190" or .165" travel ????? I'm using Peco insulfrog switches...................
  2. Catt
    Catt Guest
    Just out of curiousity ,why would you use Caboose ground throws with Peco turnouts?
    You do know that you have to modify the Pecos don't you?
    You have to remove the centering spring,or at least weaken it.
  3. rockislandmike
    Nope, I didn't know. Never mind, then. Does Peco make ground throws then, or whose would be easiest adapted to Pecos if I don't wanna buy motors for all of 'em.
    Maybe I should take the Pecos out of their cute little boxes and check them out.
  4. Catt
    Catt Guest
    Unless they are going to be out of reach just a flick of the finger will switch them from one setting to the other.There are no switch machines or ground throws required.:D
  5. cidchase
    cidchase Active Member
    hay Catt!!!
    is that called "Stub & Poke" as opposed to Stud & Probe??
    Just Checkin'
  6. alkcnw
    alkcnw Member
    I don't know, the ground throws may not be needed but they sure make it more realistic looking. I'm planing to use them on mine needed or not. I like the Caboose Hobbies ones with the target plates on them, you can tell which way your switch is directing by just a glance!:eek:
