Got That Erie Feeling
Discussion in 'HO Scale Model Trains' started by hudsonelectric, Mar 14, 2004.
  1. This is the Erie caboose kit that I've been wrapped up with lately. Because the riveted and welded steel side versions of this crummy were only available in brass, I jumped on the opportunity to get one as a styrene kit. I still have a couple of parts to hang on and some touch-up to do, but it's 95% complete.
  2. cidchase
    cidchase Active Member
    Hi Russ,
    The caboose pic is not showing, can you try again?
    I can't see the herald in your sig, either, maybe it's just me.
    :D :D
  3. RailRon
    RailRon Active Member
    Russ, I don't see the two pics either. Didn't the reply editor complain when you attached your pics?
    Cid, relax, it isn't your 'pooter which is acting up. :D :D :D
  4. shamus
    shamus Registered Member
    The reason it won't show up is because you are trying to take it off your hard-drive.
    D:\Russ' File\Model RR\Erie Caboose Kit.JPG[/img]
    Also, I doubt it would have worked anyway as the \ needs to be replaced with / (Hope you don't mind me saying this)
    All you need do is use the browser here to upload a file from your hard-drive. No more than 70 bytes per photo.
  5. neilmunck
    neilmunck Member
    70 kilobytes I hope:eek:
  6. How's this?
  7. cidchase
    Now, that's a little beauty!!:) :) :)
    Show us some more, Russ! :D :D :thumb: :thumb:
  8. TomPM
    TomPM Another Fried Egg Fan
    Nice job!:thumb: :thumb: :thumb:
  9. RailRon
    Yep, that's a pretty caboose, Russ. Fine modeling!
  10. Thanks for the comments, crew!
    The Erie built a couple of series of these cabeese right after the war in the 40s, first in riveted side steel and then in welded side steel. I can't for the life of me remember Erie cabooses when growing up next to the mainline, but I'm sure I saw these at some time. :rolleyes: This was a tough kit to build because of the lousy instructions and illustrations and the herald decals were dried out and cracked. :curse: Fortunately, I know of the small operation that made them and ordered a fresh set. I tossed the instructions out near the end and worked off of photographs in my book library. The quality of the parts, both styrene and etched metal, is superb though. This kit is a must for Erie RR's too bad that the manufacturer didn't realize the importance of drawings and instuctions. :(
    Thanks again, guys! :wave: :wave: :wave:
    Russ :sleeping:
  11. I wanted the caboose to go along with this Kato NW2. I picked it up on eBay undec and researched out the engine number and handrail configuration.
