Gapping Loco Wheels (in Atlas HO)
Discussion in 'FAQs' started by EngineerKyle, Jan 30, 2007.
  1. EngineerKyle
    EngineerKyle Member
    Hi all,
    Here's a little mystery;
    I gapped the wheelsets on my H16-44 as close to perfect as you can get. That was about six months ago. Now, after an unexpected derailment, I checked the gaps to find three of the four wheelsets were again too tight.
    Has anyone ever experienced the span between the wheels traveling with use?
  2. Nomad
    Nomad Active Member
    Nope, never have. Any way you can put a drop of ca on em?
  3. brakie
    brakie Active Member
    Yes,Several of mine did with prolong use..I put the wheels back in gauge and that was that..I suspect that is cause by the truck play that is cause by the wheels following the rails
  4. EngineerKyle
    EngineerKyle Member
    Thanks Larry,
    This will be the second or third time I've had to do this on this one loco. The others are fine. I wonder if Atlas would give me new wheelsets for it?
  5. brakie
    I would contact Atlas and see if they would since yours is not staying gauge.There has to be a problem.
