Foam Benchwork help
Discussion in 'FAQs' started by jlg759, Mar 15, 2006.
  1. jlg759
    jlg759 Member
    I have just completed two small modules with foam top for my layout. When I joined the two ends together the foam on one side where the two joined was a hair higher. Can the foam be sanded to get the foam level with the wood supports that attache the modules? To make the question simplier can I sand the foam? Thanks Joe
  2. piston_8
    piston_8 New Member
    Yes it can. Have vacuum handy.
  3. MasonJar
    What he said... emphasis on the vacuum... :D
    You can use a Stanley surform (tool brand/name) instead of straight sandpaper.
