Before I go any further I need some advice on foam. I started our layout with a piece of 2" foam for underlay. I used the white bead type foam. Is this a huge mistake? I have already glued down my cork. I used this foam for only the base on top of my bench.. As far as mountains go I wouldn't use this foam for that unless told otherwise. Will send pics when cork is all laid.
thank you
Woody
thank you
Woody
