Okay, So this is my first ever layout. Nothing to fancy but, I'm having issues getting things running correctly. Don't let the pic bother you I'm still doing a lot of work. So, Where the train sits now, it will not run unless the switches are in such a way that the train can not continue down the line. NOR can another engine run on tat inside track due to how the switches have to be. So, I played with some wiring a bit a got it to run with both Switches as I'd like them to be BUT then the train runs in reverse. That really doesn't work out well!!!:curse: I''ll post more pics and whatnot later! THANK YOU
