Finding the right window
Discussion in 'Scratchin' & Bashin'' started by belg, Mar 18, 2004.
  1. belg
    belg Member
    I'm looking for a fixed six pane window about three ft wide and 4 ft tall with a frame, I've tried grandt line, tichy,detail assoc., and campbells and cant find anything close does anyone have another source for me to look at. I also looked at the Walthers website and came up empty. A laser cut would be great.Thanks Pat
  2. mhdishere
    mhdishere Member
    SS Ltd also has some windows, at least in HO (are you still doing N or did you make the switch?)
  3. spitfire
    spitfire Active Member
    Belg, what about printing (or photocopying) your frames onto clear acetate sheets? I've read somewhere that the thickness of the toner is actually closer to prototype measurements than any castings.
  4. Will_annand
    Will_annand Active Member
  5. belg
    belg Member
    Thanks for the suggestions folks still have not found what need but if all else fails I will print them on the acetate. Thanks to mhdishere and Val for the idea.
  6. krokodil
    krokodil Member
    Look at those windows, all are printed.
    Good luck
      File size:
      39.9 KB
  7. philip
    philip Guest
    I have a few of these.
      File size:
      5.9 KB
  8. belg
    belg Member
    Philip THAT'S IT the exact window I'm looking for did you make that? or buy it? Where can I get those? Pat
  9. philip
    philip Guest
    I thought I was the only one on this early. I borrowed the window from Union Station/Walthers.
    How many do you need?
  10. krokodil
    krokodil Member
    Hi Pat,
    a little bit smaller (I think it is about 9x13 mm) you can get from Auhagen in their WINDOWS Kits. They have one bigger size as well, I will check for you the size.
  11. belg
    belg Member
    Philip believe it or not I need 42 pieces between the two buildings I'm planning. Thanks Pat
  12. philip
    philip Guest
    Pat, Oh man my windows are HO........Sorry .
    You find one somewhere to your liking and I'll make you a mold.
  13. belg
    belg Member
    Philip these structures I'm working on are being built in HO so the window is right. I would love to be able to make my own mold do you have a tutorial on this process? Thanks Pat
  14. belg
    belg Member
    Krokodil I missed your post before I tried to go to the website but No german spoken here so I was flying blind. If you could look into it for me that would be great. Thanks Pat
  15. krokodil
    krokodil Member
    Hi my Friend
    I try to link their WEB sites with those windows, they have quite a lot (but the structure of the WEB is strange for linking. Let me try.
    [​IMG] [​IMG]
    Article Numbers are 48647, 48648 , 48650 and 48550
    If this does not work, go to
    and Ausstattung, you will find them.
  16. belg
    belg Member
    krokodil I really like the set thats off to the right but it gives no dimensions for the windows and doors do you know what they are or could you ask the company in an email please. I need the grill of the exterior(do not include the glue flange in the measurement) to be about 4 HO scale feet high no more.Thanks alot Pat
  17. krokodil
    krokodil Member
    Hi Pat
    I am sure you will get the extra size of those windows from them as well. They speek quite well English.
    I have a few of them, here are the dimensions.
    The light braun with 6 glass segments has the dimensions of 7x13 mm
    The darker braun one with 8 segments is 9x18 mm, similar is the size of the white 3 segment windows.
    Always it is the frame size (opening in the wall).
  18. cidchase
    cidchase Active Member
    3.5mm = 1 HO foot
    1 mm = approx. 3.5 HO inches (the width of an HO 2x4)
    So a 3'x4' window opening would be 10.5x14mm :thumb:
  19. philip
    philip Guest
    Pat : I mailed a few windows to your address Saturday. Give em a try. They may be a little tall.
  20. belg
    belg Member
    Philip,thanks I look forward to their arrival.Pat
