Fast Clock N or HO
Discussion in 'FAQs' started by Railery, Dec 23, 2002.
  1. Railery
    Railery Member
    If N scale is half the size of HO scale. And HO scale is 1/90(1:87) in size. Then HO scale runs at 1:9 (or 1:8) fast time.;) Does N scale than run at Twice that of HO ? :rolleyes:
  2. cidchase
    cidchase Active Member
    oh, no, are we gonna try to scale time again????? :D :D
    I just can't make it work.... :eek: :eek:
    I tink HO is 1:87.1 :) :)
    I tink some mrr operators use a fast clock to permit point-to-point schedules to fit into a reasonable operating session. This does not actually bear on scale speeds, however. ;)
  3. BillD53A
    BillD53A Member
    The ratio of the clock is determined by the length of the operating session you want. On my layout, I run from 6am to 6 pm, or 12 hours. I run the clock at a 4:1 ratio, giving me a session length of 3 hours.
    This holds true, whether I model in HO or N or any other scale.
    There is a group at Yahoo called the Ry-ops-industrialSIG. If you join it, and go to the Files section, you will find a couple of programs for fast clocks, that you can use on your computer. I use one, and it has made all the difference in my railroad's operation. HTH,
    Merry Christmas, Bill Donahue
  4. Vic
    Vic Active Member
    Bill D is right...time cannot be scaled up or down...only the appearence or illusion of time can be speeded up or slowed down. Real time always remains constant or close to it until the speed of light is exceeded..."Warp 7 Mr. Sulu...we'll give those Klingons a run for their money....":D :D :D :D
  5. Railery
    Railery Member
    i didn't mean to post another fast clock question in regards to one time. :eek: i was just poking a little fun between N scale and HO scale :p Actually i have a fast clock for my layout and i use it for operations in the same manner. i can set the different ratios up to 12 : 1. Yet i like running at 8 : 1. The 4:1 ratio is good too. Here is a pic of my fast clock.:D
