dockside switcher
jimbogibbo
37
does anyone have a remedy for the switcher slowing down to a crawl when the smoke unit is turned on! they run great with the smoke unit turned off , but when i turn it on they both come to a crawl!!! this is two different locos. that do the same thing.:confused:
N
nachoman
I assume this is 3-rail O scale?
My guess is either and undersized or failing power supply, or a smoke unit drawing too much current.
Kevin
Renovo PPR
Just a Farmer
Dec 23, 2006
544
Somerset County PA
What transformer are you using? If I'm correct this is an O gauge locomotive.
With out much more information I would have to guess. My guess is that you are way under powered with the current transformer you are using.
jimbogibbo
37
these are both 027 scale one running on a railpower 1300 and the other is running on a mrc 280.
Renovo PPR
Just a Farmer
Dec 23, 2006
544
Somerset County PA
You are in fact underpowered with both of these. The first is for smaller trains such as N and HO. The second is listed for O but it is best for HO and N.
The TECH 4 600 might of been a better choice.
