DN163 decoder on Lifelike F40 problems
Discussion in 'DCC & Electronics' started by chapmro, Jan 30, 2007.
  1. chapmro
    chapmro New Member
    I installed a Digitrax DN163 decoder on a Lifelike F40. The installation went easily, since the F40 uses wires from the wheel pickups to the motor and bulb, but after installation the F40 was _slow_ (no buzzing, just very slow). I checked every wire (I have installed numerous decoders before successfully). The light works as it should, the engine reverses fine, and it does move in both directions, just about half as fast as it did on DC. I modified the speed table, tried 14 vs 128 step throttle, but couldn't get any improvement. I even uninstalled the decoder and wired it for DC again, worrying I had somehow damaged the motor during the decoder install, and it ran fine on DC. What did I do wrong? Someone told me the problem is because this loco uses a "pancake" motor?
  2. chapmro
    chapmro New Member
    Just an update -- I found out what a pancake motor is, and this loco doesn't have one -- it has the usual center-mounted motor with two shafts that go to worm gears that drive the wheels in both the front and rear trucks.
  3. YmeBP
    YmeBP Member
    I have a similar issue w/ my f7 i put a digitrax decoder into. I think there is a cv that controls the max voltage. I'l do a little more hunting around after i get my layout back together and see if that cv is the solution.
  4. YmeBP
    YmeBP Member
    read this in digitrax's manual. I'm in the process of rasing the floor of my laout so i can't test it but i plan to. Will let you know how it works for me.
  5. Marxed
    Marxed Member
    i seen this title and was hoping it was about a Ferrari F40 :)
