distance between tracks
Discussion in 'On30 Forum' started by ROD J H, Feb 22, 2008.
  1. ROD J H
    ROD J H New Member
    can anyone tell me the distance between tracks for on30 narrow gauge,I was told it is 2 inches for HO gauge from center to center of the rails
  2. pgandw
    pgandw Active Member
    HO track typically is set up for 2" separation (center-to-center) for straight parallel tracks (wider spacing is needed on curves). Whether that is enough for your On30 equipment - it probably isn't - depends on the prototype you are following. 2" = 8ft in O scale, which ain't much. 2" = 14ft in HO scale, which is very close to prototype spacing used in yards in the 1950s.
    If you look at the NMRA standards for track spacing (NMRA - S-8 Track Centers), you will see that On3 calls for 2.75" on straight track. If you are running accurate models of 3ft gauge (on On30 track) K class 2-8-2s or large outside frame 2-8-0s, you will need every bit of the NMRA standard - and even might need some more than the standard on curves.
    OTOH, if you are running strictly models based on 2ft prototypes or smaller 3ft prototypes, I have heard of 2.5" being used successfully.
    Last point on clearances - all the prototype narrow gauge track I have looked at used considerably wider than required spacing in yards and towns. I have rarely seen tightly packed tracks like in a standard gauge yard - Alamosa may be the exception.
    Also, a word to the wise - vertical clearances for On30 are going to have to be bigger than HO.
    hope this helps
