Digital Navy Fuso
Discussion in 'Ship & Watercraft Models' started by barry, Mar 1, 2004.
  1. barry
    barry Active Member
    Phillipe that's a great model of Fuso any chance of a couple more pics.
    Just starting on "Takao" i hope I do half as well!!!
  2. Corporal_Trim
    Corporal_Trim Member
    I second that. Just the "Pagoda mast" assembly alone is absolutely amazing. :shock:
  3. bwallaw
    bwallaw Member
    Congratulations Phillipe. Your work is awesome and inspirational for me. Can't wait to get to work!
    Thanks for sharing...
  4. philippe
    philippe Member
    thanks for encouragements
    i work with cyano gel glue, white 'SADER' glue (dispo in France) and Swann-morton scalpels.
    it's my first ship papermodel, i was especialy free flight scale model builder (old timer balsa, tissue, rubber powered airplanes)
    the design digitalnavy is so good that all the work become easier with a little patience.
    my next project after finishing the Fuso is to build the Arizona digitalnavy,
    ...and learn english!!
  5. barry
    barry Active Member
    I found that british corn flake packets are about 1mm thick and are good for doubling up. having been building at 1/400 this thing is large.
  6. barry
    barry Active Member
    Thanks for the new photos Phjllipe, impressed by the gun tubes
  7. philippe
    philippe Member
    the guns are made with 80g/m2 letter paper and uhu yellow stick glue
    the design digital navy is realy good.
    my next work is to find anchors chains. i will start the DN uss arizona this week end.
    best regards
  8. barry
    barry Active Member
    Takao's bridge the top "glasshouse" looks a bit better in real life edges need painting as well
  9. Jim Krauzlis
    Jim Krauzlis Active Member
    Hello Barry and Phillippe!
    Maybe you fellows can tell me how you get your decks so wonderfully flat and true? On my JSC kit the deck had a tendency to buckle a bit, but I was worried about using too thick of card stock for fear of throwing off the rest of the hull measurements. Maybe it is a problem with the JSC construction method, not sure.
    What size card stock do you usually use to avoid the buckling? Is there any other type of reinforcement that I should be using?
    I'm not that good at this stuff yet, still learning :? , and any tips would be very much appreciated! :D
  10. barry
    barry Active Member
    You can beef up the formers almost as much as you like, for decks small models I laminate two pieces of thin card, large models head for the cereal packets about 1 mm. Stick the waterline plate firmly to a baseboard strengthen the joins, stick the formers with plenty of glue then get every large book you have got and pile them on top of the decks. Egcrates are extremely strong. After Takao I intend to put a coloured strip same as the waterline on first in thin paper just in case the height is not right. Don't rush to take the hull off the board and leave the weights on all night.
  11. philippe
    philippe Member
    i use the same method to built my ships.
    i use 1mm carton found in art-store.
    the deck is printed on 80g/m2 paper, ideal is photopaper.
    before cutting, this paper is glued with spray-photo glue 3m
    on the carton on non shiny face.
    afterwards i cut out the various holes, and next the deck
    outline, with a scalpel (sometimes breakages, be careful of eyes and fingers!).
    i trace axe, and formers position on the back, i fix the deck on a stiff straight wooden plank, next i can build the hull structure, using 1mm carton. i thing that the final quality depend on accuracy of cutting of, don't use scissors, but knife and scalpel, with multiples passings. for the sructure assembling, i use white vinyl glue and i reinforce sometime with small sraps of carton, i use too books but also small pins to support assembling when the glue is drying. don't manipule the structure as long as the glue is strong.
    "bon courage!"
