decal question
Discussion in 'N / Z Scale Model Trains' started by wt&c, Jun 11, 2001.
  1. wt&c
    wt&c Guest
    would a deskjet printer (by H-P) make good decals using inkjet decal paper??
    NARA Member #8
    www.a&a.77th.com/
    The Appalachian & Atlantic Railroad
    "QUALITY at WORK with SAFTEY in MIND"
  2. Woodie
    Woodie Active Member
    wt&c,
    The printers do work fine with decal paper, however the printers you mention cannot print white. SO as long as your decals contain no white, then you are fine.
    TOOT!
  3. Matthyro
    Matthyro Will always be re-membered
    I used my Canon printer to make decals. I have used transparent for just colour ones as Woodie says but I wanted some white too so used white decal paper. A pain because I had to cut the outline so no white edges show.
    It's worth it though because you can make whatever decal you want.
    Robin
    NARA member #2
    http://members.nbci.com/Matthyro MAT
  4. Matthyro
    Another job though is to seal the decals before you put them on as if you don't the ink runs. I use Testors dull coat or the gloss coat depending on the finish I want
    Robin
    NARA member #2
  5. wt&c
    wt&c Guest
    thanks guys, basiclly what id do when painting, is I paint the loco with all colors used (afer each color and cote dries) then I wil print the decals out, then seal the decals only with dull cote. Then I decal the engine, then weather it and seal again with dullcote. That worked with my 3 csx sd40-2's back when I was in HO scale. (8350 sold on ebay for $45 and it was an unpowered athearn!)
  6. billk
    billk Active Member
    wt&c
    There is a brand of printer that prints white (it has white ink, duh). I memory fails me right now as to what brand, but if you're interested I'm sure someone out there could tell you.
    Bill K
  7. billk
    billk Active Member
    Follow on to my last reply - I think its called an ALPs printer - do a web search for +printer +decal +white
    Bill K
